Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Help with replacement parts
I have a k5ss solid state i had for 2 years i need a flat beater and dough hook the white coating is coming off why i do not know..and i cannot afford to buy new ones...i also have a kitchenaide ksm90 and when i am mixing with the wire whip the wires come out of the prongs when i try to put them back in it comes again..what can i do? do you have any parts around i can use..thank you
  • 234 Answers
I know it's expensive but you will have to replace the parts.
Your cheapest bet is to check Ebay for used parts.
You may be able to find used parts at an appliance repair shop also.
You could also put an ad on Craigslist to see if anyone in your area wants to get rid of parts
Posted on Apr 17, 2009
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
Your beater to bowl adjustment may have come out of alignment, which can happen over time with normal use of the machine. This simply means that the flat beater may be contacting the bottom of the bowl.
In your mixer's Use and Care Guide, the beater to bowl adjustment is covered and will provide easy instructions to follow about how to adjust your beater back into proper position.
There are burnished aluminum beaters available. That is to say, they do not have the food-safe nylon coating on the outside of them. Burnished aluminum beaters may not be used in the dishwasher, require hand-washing, no soaking, and immediate towel drying. Failure to follow exact washing instruction with burnished aluminum beaters may result in tarnishing of the beaters.
May 27, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 | Food Mixers
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
147 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
