Question about Turboair GSB-49DR
Right door upper right hindge brokin wont close on its own
The bottom freezer door right side is not closing all the way and causing ice to form in the freezer. This just started a few weeks ago.
YOU NEED TO CHECK UR DOOR SEALS AND READJUST UR DOORS AT THE HINDGES. IF U HAVE CHILDREN WHO LIKE TO SWING ON THE DOORS IT CAN CREATE A LEACK DUE TO BAD DOOR ALLIGNMENT
Jun 20, 2015 | Refrigerators
How do I adjust the oven door to allow it to close
I had this happen before, it was because I did not put the door back on exactly right. Remove it again and be sure to line up the hindges just right when re-inserting the door. It might take a few tries.
Dec 22, 2014 | Cars & Trucks
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Door will not close
Did you take the door off (moving or new purchase) to bring in the house? if you did then you didnt put the door on correctly. never heard of a door go from fine one day to not closing. take door off and make if the bushing is still on the bottom hindge. re attached door in close position.
Mar 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer door
Hi, before you put this part on, have you tried adjusting the door hinge at the tp of the refrigerator? The part you described sounds like the door stop and I do not thing=k this will solve your problem. The top hinge can be loosened and then push the top of the door away from the other door. Please let me know if this helps at all or if I can assist you further.
Thanks
Vic
May 21, 2009 | Frigidaire FRT18P6BS Top Freezer...
Door hinge stretching
I just changed mine and it cost around 40-45 dollars. It took around 1 hour to complete with a second person. Go online and google the hindge assembly for the modle and year vehicle there are many parts dealers with great prices out there. All you need is a floor jack, an open end or closed end wrench, rope to tie off the door and time. Not a big deal
Ray
Apr 28, 2009 | 1999 GMC Jimmy
I have a amana Electric smoothtop range and the door wont close due to my child standing on it so its bent. Im trying to figure out how to take the door off and fix the hindges my self?
you will likely need to replace the hinges part # 74010546 (requires 2) , which are $26.00 each and are located inside the door. The door would need to be removed and then taken apart. Also you may need hinge receivers which are part # 70010551 $7.09 each. These are located on the oven cabinet and can be accessed once the door is removed.
Apr 09, 2009 | Amana AER5715QAS Electric Kitchen Range
SONY VCR SLV750HF WILL NOT EJECT OR PLAY.
Hi dear look like loding gayr broken if it is then u can't do much about it even theu u figure out the gaier brokin .ok cheack the gair under the mechnisem or right hand site all vcr gair have timing set up with a mod swtich every gair have mark on it or holin it .they have to match ....if dont find any brokin gaier so find the mode switch trry to clean that some time they get old & contcat not good any mor function error (make sure the timing of gayer very important mark evry step u do so u can put back to gather )good luk
Nov 04, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Turboair GSB-49DR Logo
20 people viewed this question
Top Turboair Refrigerators Experts
David Jewell
jasbo
jasbo
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
