Question about Canon NP 6551 Black and White Copier
Poor copy quality - lines on paper
Canon np 6025
When I make a copy on this machine the copies have lines which are parallel to the long edge of the paper, roughly the entire length of the paper. These lines are bunched up about 2 inches from the edge. . I cleaned the drum, but the problem returns after a few copies. Toner is full. Any ideas?
  • Anonymous Mar 19, 2014
    the edges of the paper is ripping as the copy is being made. also the machine gets hot rather quickly
    President:
  • Canon Master
  • 990 Answers
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Posted on Jan 24, 2009
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Jamming paper
you have to replace paper pick up roller set
Dec 14, 2008 | Canon NP 6551 Black and White Copier
A straight line on paper
need more info.
white line - black line ????
copying from glass or doc feeder or both ?????
Oct 09, 2008 | Canon NP 6035 Copier
Lost copy code on Canon NP 6025
It can be reset, but you may have to fix the problem first. And what is the problem with the copier, is it a 6025 or6551?
Jul 15, 2008 | Canon NP 6551 Black and White Copier
Canon np6025
I have a NP 6025 that is jamming from the letter tray top not multi purpose tray. I cleaned the rollers that did not help. its making a grinding noise (best way to describe it) The paper gets jammed at various stages in the input unit I can open the right door and see the paper. Wondering if anybody has any ideas on how to fix this problem....
Sean
Feb 16, 2008 | Canon NP 6551 Black and White Copier
Poor quality copies on Canon imageRUNNER 330
the image drum needs to be replaced
thanks for rating
Jan 10, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Poor quality copies from the Canon NP 7130F
hi im jules_09.have check the drum unit and the fuser unit check the two unit.first of all the drum unit the drum may be scratch or damage that goes with the fuser unit too.
Dec 12, 2007 | Canon NP 7130 Black and White Copier
NP 6025 printing Crooked
yes ther is ! first clean the glass with Mr Sheen(which is a spray on furniture polish) the glass needs to be slippery so the paper slides nice and easy over it.Then if that doesnt help,where the feeder attaches to the machine are 2 hinges one of which you should be able to adjust. Hope this helps.
Aug 19, 2007 | Canon NP 6551 Black and White Copier
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
May 29, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
223 people viewed this question
old marine
old marine
Corne Viljoen
