We have an OCE 450 that is giving an error code of 8508. It occurs as the OCE is about to plot and the paper is feeding. Any ideas? Thanks
checkitright
  • 1362 Answers
SOURCE: Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Posted on Oct 29, 2007
pagebor
  • 2785 Answers
SOURCE: My Canon printer mp 530
it needs servicing
Posted on Jun 24, 2008
SOURCE: paper will not feed
I am having the same issue rite now. . the only solution is to Upgrade its firmware per HP. but i cant seem to find a English version.
Posted on Aug 12, 2008
SOURCE: Error in Oce 9400 Plot Director Win 2000
There are a few possible solutions.
First, only the last version of Plot Director (3.4.3) works in Windows 2000, so make sure that is the version being installed.
Secondly, once PD is installed and uninstalled all registry references must be removed before attempting to reinstall or you will encounter errors.
Third, make sure you have Administrator privileges when installing or editing the program.
Last, because there has been no development on PD since 2001 it may be having issues with security, such as the ability to edit files that are in a protected zone or communicating thru a firewall.
As a test make sure that none of these programs are active during installation or configuration.
Posted on Mar 03, 2009
SOURCE: Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Posted on Jul 10, 2010
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
HI I AM GETTING ERROR CODE FOR MY OCE 2060 COPIER
There are many types of error codes, however here is one solution on a specific type found in fixya:
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC. Pretty technical :) kc
Mar 18, 2011 | Office Equipment & Supplies
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
My Oce im2520f is giving me an error code: C0500. After about 3 minutes of giving me the error code, it beeps four times (long beeps) and then in shuts off. Anyone have any idea what it might be?
The C0500 error code is a fuser unit error code. The fusing unit is the part that gets hot and "fuses" the toner onto the paper just before it exits the machine. There is a special reset procedure for this code so as to prevent overheat of the fuser. You will need a service technician to diagnose the problem in the fuser and then reset the code. Most common causes are blown thermal fuse, bad thermister or rarely, a bad heater lamp.
Good Luck and Thank You for using Fixya.
Mar 19, 2010 | Office Equipment & Supplies
OCE TDS600 Error Codes
Jul 13, 2009 | OCE Office Equipment & Supplies
OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
96 people viewed this question
jasbo
jasbo
