Question about Maytag Appliances Over-the-Range Microwave Oven
Micowave continues running after time is up
The microwave will continue to cook even though the time of 30 seconds is up, so after it beeps the microwave just continues to run
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
This can be two things that I know of 1 is a timer defect and the other is someone has placed some type of metal ie utensil, foil, can whatever into the microwave - either way you should replace the microwave and its a fire hazard to your home and others around you and the cost of a new unit is not worth the losses a fire can bring.
Posted on Jan 14, 2013
My microwave continues to run 2-3 seconds after cook time. It doesn't seem normal but it works fine otherwise
Microwaves are cheap, if you are worried replace it, With what i k now about electronic clocks I am willing to bet it's not a safety issue.
If you want to be sure you could measure the amount of current it is drawing from the outlet and compare this with the specifications on the back of the microwave. Either get a "kill-a-watt" device, a multimeter with a current probe, or if it draws less than ten amps according to the sticker on the back you could use a regular multimeter to measure the current by hooking it up in series. The "kill-a-watt" is a brand name for a device that plugs into the outlet and then you would plug the microwave into. It will measure the amount of electricity it uses and display it on a screen. This device or the current probe would be the safest as you don't touch the wires. Hooking up the multimeter in series requires splicing wires.
Apr 04, 2015 | Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
50 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
