Question about Dewalt D25900k Heavy Duty Demolition Hammer Breaker
Dewalt 25900 Hammer Drill Won't hold a bit.
My Dewalt 25900 Hammer Drill won't hold a bit any more-is there a schematic or replacement list I can get to fix it myself?
  • 2,176 Answers
Yes there is I looked and the model number posted is a demolition hammer, so you might want to recheck before checking, but go to Dewaltservicenet.com and in the middle of the page it will ask you for parts or below that manual, go to manual and type in your model number and you will get an explosion and current pricing for this tool. Let me know if I can help I work on their demolition hammer on occasion. Good luck
Posted on Jan 23, 2009
Chuck won't hold bit when making drilling a hold or trying to reverse a screw, etc.
it sounds like you will need to replace the chuck on the drill. a worn chuck or a cheep brand may be your trouble.buy a good Jacob chuck and this will most likely fix your problem
Jun 20, 2013 | Dewalt 18 Volt Compact Drill Kit
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Feb 15, 2012 | Dewalt Drills
Good battery but drill won't run
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Jun 09, 2011 | Dewalt DC925KA Factory Reconditioned...
Need repair schematics for dc988 dewalt cordless drill
web search-dewalt dc988 schematics-click on 2nd site,{parts list and diagrams
Oct 06, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
I need the electric schematics, trying to replace the switch.purchased switch thru the dewalt website.
Schematic from a dealer for converting an old type 1 switch on DW-505 hammer drill a to the new switch. 124845e.jpg
Oct 04, 2010 | Dewalt DW505 Electric hammer drills
How do you put the drill bits on this drill?
Grab hold of the sides of the check and run it in revers to open the chuck and then place the drill bit in the chuck and run it forward while holding the side of the chuck to tighten it on the bit...
heatman101
Jul 15, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Was using with a spsde bi and hit a nail. Now
You may have inadvertently hit the hammer/drill switch and it is floating the middle between functions. This selector switch has a symbol showing a drill bit on one side and a symbol of the hammer on the other. Engage the switch bacK into the drill position
Jun 08, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt D25900k Heavy Duty Demolition Hammer Breaker Logo
686 people viewed this question
Top Dewalt Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
richie46
Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
