How do you put the staps back together after washing the carseat cover of a Costco Scenera 5 point carseat.. Not sure what to do with the metal piece in the back after I put the straps through. Cannot get the straps to anchor down so they don't come out..
Thanks.
Here's a manual:
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope this helps!
There are loops at the end of the harness straps. Feed the curved part of the Y plate through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - in order for it to do it's job properly, it needs to lie in line with the child's armpits, not up in the neck or down over the belly.
what is harness straps
there are instructions on how to put the carseat back together on the strap located at the bottom of the carseat!
