Question about Kodak EasyShare One Digital Camera
SD Card will not go down all the way
My SD Card will not lock into place in the camera.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Donna, You may have a damaged contact inside the camera, it will have to be looked at by a tech.
Best Regards, Russell
Posted on Jan 24, 2013
SOURCE:
My memory card won't lock in place therefore I get a "no memory" card message.
Unfortunately it sounds like the locking clip inside the SD card slot is broken or some how stuck? If you can try to look inside the SD card slot in the camera with a flash light, there should be a small clip like plastic to the left sticking out. That is what locks the SD card in place. See if anything is stuck in between like debris, you might gently poke that clip and see if it is stuck? That is what locks the SD card in place, if it is broken or missing, that will require some work to replace the plastic lock.
May 25, 2014 | Canon PowerShot SX10 IS Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I PUSH IT INTO SD SLOT
  • Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
  • Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
  • Dec 05, 2010 | Bushnell Trail Scout 11-9500c Digital...
    I just removed the SD card to view some pictures and now when I put it back in it will not latch and stay down. I have tried two other cards as well and none will latch and stay down. They do not seem to...
    The first thing that comes to mind is to make sure you have it in the right direction. You should have the metal connectors of the CD card facing AWAY from the batteries. Even if the card fits the other direction, it is a must to have the connectors the right way.
    Some CD cards are affected in use by whether or not they are locked or unlocked. Even if you don't remember locking the card, those things can be slid pretty easily. Check to see if perhaps your card got moved to the "locked" position. (The lock is a miniscule little slider to the left of the label on most SD cards. It should be at the TOP to be unlocked, unless your brand has printed directions that differ on the card itself.)
    Also, you can always try turning the camera upside down with the battery door open. Don't hit it, but if there was a little piece of dirt, it would hopefully fall out.
    The SD cards need a little quick push to lock into place, and need a quick push to unlock as well.
    If you check on all of these, and it still isn't locking into place, it is possible that there is a bent pin on the SD card. I haven't experienced a camera that had a problem with the SD slot yet in 8 yrs of owning digitals, but I have had bent card pins...
    I hope one of those helps you.
    Oct 01, 2010 | Canon PowerShot A1100 IS Digital Camera
    My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
    Turn the Canon Powershot A560 over so the bottom is facing up.
    Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
    Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
    Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
    5
    Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
    6
    Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
    7
    Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
    8
    Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
    Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
    SD card Protected
    It sounds like the tiny locking switch on the SD card has accidently been set to "lock". Remove the card from the camera and slide the switch to the opposite position. That should do it.
    Apr 25, 2009 | Fuji FinePix Z10fd Digital Camera
    I cant get my pentax optio M20 unlocked
    Do you have an SD card? If so you need to remove the card from the camera and look closely at the front of the card. You will see there is the little grey tab slider button on the left side. If it is pushed down into the locked position then you'll need to slide it up to unlock it. Then place the SD card back into your camera and all should be well..... Good Luck and Hope this helps you!
    Mar 13, 2009 | Pentax Optio M20 Digital Camera
    Sd card won't stay in the slot of my nikon coolpix S210
    See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
    Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
    Coolpix l5 - SD card won't seat
    The Nikon are very good about placing a sd symbol on the door of the memory compartment. The trick is to align the dog ear side of the memory stick with the picture on the door the push down until the stick bottoms out in the slot it should then lock in to place. Conversely to remove it push down again until it un locks.
    Dec 07, 2008 | Nikon COOLPIX L5 Digital Camera
    SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
    The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
    Sep 29, 2008 | HP Photosmart M525 Digital Camera
    Kodak EasyShare One Digital Camera Logo
    16 people viewed this question
    Top Kodak Cameras Experts
    Vitally Alcher
    FIKRET UNALIR
    FIKRET UNALIR
    Level 1 Expert
    Jerry Greenberg
    Jerry Greenberg
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
