Question about Dell Dimension 2300 PC Desktop
Dell Dimension 2300 - NO POWER
Am not getting any power or lights or action of any kind. What's the voltage suppose to be on any of the "P" type plug-ins? I have a volt meter to test with but need the proper voltage setting to check circuits.
  • 3 Answers
You will need to replace your power supply by the sounds of it, pending on your devices, a 450 to 500 watt power supply should do the trick.
Just make sure that you have the proper power connections on it like the IDE connectors or sata
Posted on Jan 23, 2009
Dell dimension 2300 will not power up unless I pull the power button connector out slowly
It Sounds Like Your PC Is Defective Because First Of All There Shuld Not Be A Power Button Connector To
Remove In The First Place And Second The Power Button is What You Turn On The PC With So It Is
Best To Replace The PC With One That Uses An Intel Pentium 4 Prosser!
Oct 10, 2014 | Dell Dimension 2300 PC Desktop
Dell dimension 2300 not powering on
This may be because of the following reasons.
1: Your SMPS may be faulty
>In this case you can replace it easily.
2. Your Motherboard can be faulty.
>In this case, you may need assistance of a trained service technician to check the whole circuit of motherboard.
3. May be the power cable to your CPU may be faulty
>Replace it with a new one.
Oct 10, 2011 | Dell Dimension 2300 PC Desktop
How do i wipe windows xp and hard drive of my pc
press windows key + R Type:- diskmgmt.msc & press enter
In the new screen select your XP drive eg:- C:\ at the top select action & select Format. (Formating the drive will over write all your XP installation)
Jul 03, 2010 | Dell Dimension 2300 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
Installed new dell motherboard per tech, installed new Dell power supply as it died too. This is a Dell Dimension 2300. It won't start.
Check all connections, to the motherboard, and also to the wall Verify that the power supply is actually switched into the ON position at the rear of the computer.
Mar 09, 2010 | Dell Dimension 2300 PC Desktop
Dell 2300 motherboard map I want to know where is power conecction
Here is the download link to the the manual (pdf format) you seem to need.
Feb 08, 2010 | Dell Dimension 2300 PC Desktop
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Jul 12, 2009 | Computers & Internet
I have a dell dimension 2300 that turns on, but the power light won't light up and the screen is blank.Is it a motherboard problem or power supply problem.
I've run into the problem several times and it can be both.Your best bet would be to try the power supply first, being the cheaper and easier of the two. If you have another desktop you could try swapping the power supplies to test (make note of which plug goes where, it's fairly simple as long as you pay attention).
If you don't have a spare then it's possible a local tech store would have one you can purchase or pay them a small fee to test for you.
If swapping them doesn't work then it points at the motherboard.
Hope this helps :)
Apr 16, 2009 | Dell Dimension 2300 PC Desktop
Dell dimension 2300
I don't know what TRIPS out sounds like, but there are number of different things that could make sounds when powered up. Let me know what and where the sounds are coming from. I am including a link for delll support for your system. Let me know if I can be of any more help. Larry
Mar 06, 2009 | Dell Dimension 2300 PC Desktop
Dell Dimension 2300 PC Desktop Logo
74 people viewed this question
Alun Cox
