Question about Polaroid FLM-3734B 37 in. LCD HDTV
3 Polaroid Tv's with lines, green or quit working
I have 4 polaroid tv's and 3 of them are now messed up I have had them in and out of the shop and still not working so what is it with polaroids they are all that I have and I want them fixed or my money back please help out of warranty
    Sergeant:
    Champion:
  • 267 Answers
Any colored lines running vertically or horizontally is a bad panel. Not worth repairing.
Posted on Jan 24, 2009
Tv codes
What problem are you having?
Try using Mitsubishi codes if the Polaroid codes for Direct TV. Mitsubishi code: 10178
Toshiba code 678 works for a Polaroid TV model FLM-1514B
Polaroid tv/dvd combo is 1991.
The dvd code equivalent of that code is dvd 1480.
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
Make and model of your TV would help...thx
Dec 27, 2010 | Polaroid Televison & Video
Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
Nov 28, 2008 | Polaroid FLM-4201 42 in. LCD Television
No picture
if nobody will repair the tv, then your probably better off buy a new one. yours could have the bulbs blow, there could be something wrong with the board or the power supply. i don't recommend working on a tv because they are very easy to mess up and do even more damage. for your next tv, get a higher rated brand like samsung or sony. they tend to be more reliable and are easier to fix/find somebody to fix
Oct 21, 2008 | Polaroid FLM-4201 42 in. LCD Television
No picture
i have the same problem. i took my tv to radioshack, and they said that they dont tale tvs that are bigger that 27 inches. so i took to one of these places that fix tv, they are charging me $270, beacuse they have to change the power supply and sometranssitors,
Sep 20, 2008 | Polaroid FLM-4201 42 in. LCD Television
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Nov 19, 2007 | Polaroid FLM-2632 Television
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Tv won't come on
chech ur line trasiformer frist of all check the collector voitage if it is ok
Jan 20, 2007 | Polaroid FLM-2601 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
322 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
