Question about Konica Minolta Office Equipment & Supplies
Error c5102
  • Konica Minolta Master
  • 1,294 Answers
Check the main motor.
Posted on Feb 05, 2013
Error code c5102
take each of the image units out not toner image units. Then shake each unit along its axis to spread the developer in side each one along the whole image unit. then reinstall. next pull out the transfer belt and reinstall properly. if this does not work you might have and burned out main motor or worse the control board that controls it is bad.
Oct 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
Error code 5102 on konica minolta c253
According to the service manual, Code: C5102 Code C5102 Description Transport motor's failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check. 5 Change M1. 6 Change PRCB.
The technical sites say that there is probably a paper jam. If the jam is cleared but the error persists, the transport motor will probably need to be replaced. This motor has a pretty high failure rate. A qualified copier technician should be able to change it out in 30-60 minutes.
Aug 30, 2015 | Konica Minolta Office Equipment & Supplies
C5102 malfunction detected c5102
Main Motor failure to turn. Remove all the image units then shake each one side to side. What you want to do is spread the developer (Located inside the unit) along the entire length of the image units. BET a all the image unit was stored up & down, instead of flat, person just picked it up and installed it. All the developer was sitting at one end so the motor could not turn correctly. NEVER EVER STORE I/U UP/DOWN always flat!!! Open & close the front door to reset the code. If code comes back then you might have already burned out the motor, or worse case the Control board went bad. But first replace the image unit with a new one cheaper. Cheaper, then having a Technician come out to check the motor and control board.
Jan 23, 2014 | Konica Minolta bizhub C250 All-In-One...
Error Code C-5102
C5102 Transport motor's
failure to turn
Some thing is binding the drive
Aug 22, 2013 | Konica Minolta Minolta Bizhub C353 Copier
Bizhob 250 c5102
The error code C5102 is a fixing unit error code.
Dec 23, 2012 | Minolta bizhub 350 Black and White Copier
Error C-5102 minolta C450
C5102: Main Motor's failure to turn
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the PWB-M connector for proper
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M - -
6 Change PU1 - -
thanks&regards
Sep 06, 2012 | Minolta Di3510f Bizhub Copier
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Apr 17, 2012 | Konica Minolta Office Equipment & Supplies
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
77 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
