Question about Tascam US428 USB Digital Controller
Can i use tascam us428 into osx 10.7.5 - Tascam US428 USB Digital Controller
What is the ohm value of the input volume controls on this amp?
For the Tascam DP-01 Digital 8-Track Portastudio, here are some of the specs:
  • Analog specifications
  • Inputs (A And B) 1/4" Phone (Unbalanced)
  • Input Impedance: > 10k Ohms (Max), Or 1 M Ohms (A Only) With Switch In
  • Guitar Position: 2.4 K Ohms
  • Nominal Input Level: -10 Dbv -
  • Maximum Input Level: +6 Dbv
    Effect Return 2 X 1/4" Phone (Unbalanced)
  • Input Impedance: 10 K Ohms
    Stereo Mix 2 X 1/4" Phone (Unbalanced)
Courtesy of Musicians Friend
Mar 27, 2011 | Tascam Audio Players & Recorders
Safari doesn't work on this used Imac G4 I just bought, but Camino does work? How do I get Safari working on this old thing?
On the left Top of your monitor is a apple Logo.Tip on it and select "About that Mac" A Window pops up and you select "More Info" it shows you the OSX on it. OSX 10.3 or OSX 10.4 Google "Safari Browser for OSX 10.? " Download it and it will work. You may have the latest Version.
Oct 04, 2010 | Apple iMac G4 Desktop
Which sound card i can use for tascam dm 4800
I use an amazing Sound Unit in place of a sound card. It works with USB 1 or USB2 port. It is Called the EDIROL UA-101 Hi-Speed USB Audio Capture unit. It is 24bit 192kHz and 10-IN and 10-OUT ports. Works like a charm with superb sound Quality
Jul 03, 2009 | Tascam US-144 Sound Card
How do I access "let's Ride! Corral Club" game on a Mac OSX 10?
game might not be compatable with your system. check to see on the game box.
May 03, 2009 | Computers & Internet
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Error 300
OSX support for Powerbooks is VERY sloppy. Try installing the iP90 in "Classic" (OS9.2.2) instead. 922 has built-in drivers for every port on Powerbooks. OSX can't even load a SCSI card on laptops. Or iRda, or any USB above 1.1 etc.... very shabby. Apple was sued for "abandoning" Powerbook support with OSX and LOST a BIG class action. Alternatively, partition your HD with TWO operating systems, and load 9.2.2 as a boot option (with OSX as the other). OSX is "emulating" 922, but this method allows OS922 to "run itself". It is MUCH faster (boots in 10 seconds, compared to MINUTES for OSX) and your iP90 will work on USB or irDa -both! 922 will only need a 700mb partition at least... OSX needs 4gb or more (to accomplish far less, far slower)
Dec 02, 2007 | Canon PIXMA iP90 Mobile Printer
Tascam US428 USB Digital Controller Logo
101 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
