Question about Saws
Change grinder disc on 7470-04 work wheel - Saws
2 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: halfords brand 380122 grinder disc changing ?
If it is a late design, there should be a button, on the 'head' of the grinder, which stops the disk from turning.
Then you should have a spanner key, that fits in the nut that holds the disk on, turn in the 'Left hand down' direction to remove.
However, if it does not have the said mechanism,
you could always use 'Shock' treatment to remove the disk.
Take a hammer.
An old flat blade screw driver.
Now wedge the disk so it doesn't turn, and place the tip of the screw driver in one of the holes, of the nut that holds the disk in place.
Now strike, until it comes loose.
This method works every time, but there is a small amount of damage incurred.
ps. Don't hit your hand:)
It hurts.
Good luck with that.
Posted on Jul 24, 2009
How to Change a angle grinder disc
My angle grinder came with a special wrench to take off the disk. I have a small button to push that locks the shaft. I push it gently with it UNPLUGGED while turn the grinding wheel by hand till it locks. Then I use the wrench to undo the "nut" that holds the grinding wheel on.
Sep 27, 2014 | Saws
How do I change disc
Mine came with a special wrench that fits into the "nut" that holds the wheel on. Make sure the grinder is unplugged. Mine also has a button I push in that locks the shaft.I lock the shaft put the special wrench into the nut and spin it off.
Sep 13, 2014 | Hitachi G23sc2
Grinder manuals
The grinder should have come with a special wrench that fits the "nut" that holds the wheel on. There should also be a button to push to lock the shaft. With the grinder unplugged gently push the button in and turn the wheel till the shaft locks then put the whrech on the nut and spin it off.
Sep 07, 2014 | Craftsman 4 1/2 in. Small Angle Grinder
How to change a grinder blade on a ryobi grinder
Handheld grinder or bench grinder? I'll assume you're asking about a handheld grinder.
Engage the arbor lock. You may need to rotate the wheel until you find the spot where the arbor lock locks the wheel. Use a wrench or a gloved hand to unscrew the wheel (I use my bare hand). Screw the replacement wheel on and disengage the arbor lock. The new wheel doesn't need to be very tight, it'll tighten itself as you work.
Jul 15, 2014 | Saws
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    My Grinder is jammed wheel is moving very hard what should i do please suggest immediately
    Just a shot in the dark, check to make sure "lock" is not partially engaged (Black button on top of grinder used when changing blades/discs)
    Feb 28, 2011 | Bosch 5" Paddle Switch Small Angle Grinder
    I have a dewalt 4 1/2", 120V angle grinder. I am breaking the thin cutting wheels when I use them very quickly or I pull out the stamped metal ring in the center of the cutoff wheel. The RPM rating...
    If you are using these disks you need to apply very light pressure with the angle grinder and ensure you aren't putting any side pressure on the side of the disc.
    Also imagine a line at a tangent to the disk. This should be kept at a shallow angle to the work piece to prevent the edge of the metal digging into the cutting disk.
    As a rule of thumb you have the correct angle when the sparks are flying at less than 30 degrees back towards you.
    Also make sure the retaining flange nut on the angle grinder is the correct way around to grip the disk, sometimes the nut has to be reversed to grip grinding discs.
    Nov 24, 2010 | Dewalt Welding Tools
    To sharpen tools
    The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
    Jul 29, 2010 | Delta ShopMaster 8in Grinder with Light...
    How to replace the grinding wheel?
    there should be a button to push to hold the wheel while using wrench
    Aug 04, 2009 | Dewalt Small Angle Grinder 4 1/2"
    Saws Logo
    Top Saws Experts
    Tom Chichester
    ray gallant
    Are you a Saw Expert? Answer questions, earn points and help others
