I have flash my computer on i cannot access the internet why?
I want to know how to access it
How do I access the internet
hi chris.
If you want to access the internet at home, you'll need an Internet Service Provider (ISP) and a router to connect to the ISP. ISPs often provide a router with their service. This means more than one computer or device in your house can use the broadband connection at the same time.
Internet access and broadband ' nidirect
https://www.nidirect.gov.uk/articles/internet-access-and-broadband..
or you can click on this link and have a read up.
How do access the internet Google Search
Nov 01, 2017 | Internet Computers & Internet
What does it mean when the far ethernet light is flashing fast and the cable light is flashing slowly. the power light and on line light are on steady. I have internet access when connected direct to...
Try this:
  1. Disconnect power to modem
  2. Disconnect power to router
  3. Shut down PC
  4. Wait 2-3 minutes
  5. Reconnect power to modem, and wait ~ 1 minute
  6. Reconnect power to router, and wait 30-60 sec.
  7. Reboot PC
  8. Try to reconnect to internet...
Jan 15, 2018 | Arris Touchstone 450a (CM450) Modem
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
My Motorola Sb5101 modem will not let me access the internet, the send light constantly flashes and i can't attain any internet connection.
If you have the following lights :
Power light - on
Receive light - flashing
Send light - flashing
Online light - off
PC/Activity - on
Standby - off
Then your Network Access is OFF - modem is successfuly registered but Network Access Control is disabled via DOCSIS configuration file.
Call your internet service provider....
Nov 06, 2009 | Arris SURFboard SB5101 Cable Modem
Cannot find wireless network on Secondary computer
Try this, unplug the power from your modem, wait 25 seconds and plug it back in. Unplug the power cord from your router and wait 10 seconds.. plug it back in. Wait for the Wan/Ready/Internet light on your modem to stop flashing or go to its default position. Reboot your 2ndary computer. Try the internet again. If this does not help please post again and we will dig deeper! Good Luck!
Aug 30, 2009 | Computers & Internet
Incredimail
Based on the small amount of information provided, I'm assuming that you may being receiving an error stating that the page cannot be displayed.
If there's no problem with your connection to the Internet and you're positive that you are connected then install a different Web browser such as Firefox, Opera, Google Chrome, etc. If you're unable ot access the Internet using your Internet Explorer icon then you will have to use a different computer to download the installation files for the Web browser. After you download it, you will have to save it to something - a CD, flash drive, floppy - something. Take it to your computer and install the browser. Launch the browser after installation to see if it works.
A possible cause would be a firewall blocking all Internet access. This means that you would need to turn it off or reconfigure the settings to allow you to access the Internet.
This issue could also be due to the configuration of your connection and, since I have no clue how you're connecting (dial-up, wireless, broadband), I can't help.
A router may even need to be reset. Who knows...
Mar 25, 2009 | Dell Inspiron 6400 Notebook
Internet explorer not responding
I will tell you the easiest way to fix this issue.
Get yourself some blank CDs or a flash drive.
Find a computer with Internet access (such as your local library, at a friend/relative's house, work, etc.).
You had to have access to the Internet to post this problem...go back and use the computer you used to access this site.
Download the installation file for Internet Explorer then save to your disk or flash drive.
Uninstall IE and re-install it using the file that you have downloaded.
While you're downloading Internet EXPLODER (YES I MEANT WHAT I TYPED), you should also download Firefox (free Web browser) and install it too. I promise you'll hardly use IE anymore and Firefox is more secure than using IE (as it is a component of Windows making you more vulnerable to security risks).
Well, if you still have the problem or ever do in the future, I hope this helps anyone who sees it.
Jan 10, 2009 | Yahoo YHT-630 System
I have a netgear wireless router and can access the internet from 2 computers on the network. The third computer has a WG111T adaptor which accesses the network but when I try to access the internet I get...
Does the 3rd PC have XP on it?
Do a search for WinsockxpFix on Google, download onto a flash drive and run it on your 3rd PC. It will reset your network files on your PC. when it finishes it will ask you to restart the PC. Then you should be able to get on.
Also, did you check if your firewall is blocking the Internet?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 18, 2008 | Computers & Internet
Swf downloaders...
If you can view it with internet explorer, then it was downloaded to your temporary internet explorer files (cache). You can find the directory where the temporary files are stored here: C:\Documents and Settings\YOUR-USERNAME\Local Settings\Temporary Internet Files or On Internet Explorer 7.0 click on: tools->internet options: On Browsing History click on Settings and then View files. Search for the file in question and then copy it to your desktop or any other folder. Let me know if that solved your problem, Daniel
Aug 28, 2007 | Macromedia Flash MX
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
