Question about Toshiba Satellite A15-S127 Notebook
Follow-up Will the power supply have the fan attached to it for the Toshiba A15?
  • 741 Answers
The fan and power supply are all one unit. You cannot disconnect the fan from the power supply. So to answer your question, yes the power supply will have the fan connected to it.
Don't forget to rate this solution before you log out.
Posted on Jan 23, 2009
My Toshiba is having cooling system issues, the laptop makes noise when the fan is on, and it stops and starts arbitrarily. The system becomes terribly slow and shows a popup saying "cooling system...
Hi, you can try to clean fan with a compressed air can, if the fan works most of the time this helps and you will not need to take anything apart, just pick up one at your local electronic store, follow the safety instruction on the can and spray all the air ways starting with the openning under your fan, but start SLOW and gradually increase the air flow and be very careful not to let the air pressure break the fan fins by sudden changes in the air flow... As for the pop-up it may not nessesarly mean it is heating problem, it may be a virus and you may want to install and anti virus just in case... Best od Luck
Jan 17, 2011 | Toshiba Satellite A15-S1292 A15-S157...
My soninlaw put a bigger hard disk into an old
Get the new power supply for it. I don't see the HDD causing it to go out.
Apr 27, 2010 | Toshiba Satellite A15-S129 Notebook
Toshiba a15-129 laptop--Will not turn on. Yellow
Your laptop is having a power problem. There was one Toshiba satellite pro that my friend had, it gave exactly the system fault as yours. And by the time we checked, it was a power problem.
The laptop had one IC that controls both the power and the entire board. If anything happens to that IC, it will affect the whole board.
I hope yours is different, because if it is the same, it will result you replacing the whole laptop mother board.
I would advice that you take your laptop your a qualified specialist, so that the fault will be made know and solution will follow.
I wish you the best.
Dec 18, 2009 | Toshiba Satellite A15-S129 Notebook
DC power light is blinking orange on my Toshiba Satellite a15-s1292. Nothing else is working.
In general this indicates a problem with the power supply, this a very difficult error code to decipher unless you are familiar with hexadecimal code. I suggest you contact Toshiba Technical Support.
Sep 23, 2009 | Toshiba Satellite A15-S129 Notebook
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
Cooling Fans compatible with Toshiba A15 laptop
You can't replace the fan, you have to replace the power supply. In order to find out whih one you need the best thing to do is open your PC and find out the Wattage. It will be marked on the outside of your power supply. Just in case you do not know where the power supply is, if yo see where the vents are on your computer the power supply is there. It has a fan to blow the hot air out of it..
Don't forget to rate this solution with four stars before you log out.
Jan 23, 2009 | Antec TriCool 3.125" LED CPU Cooling Fan -...
yes, my friend in effect, the led amber turn on and on having pressed power button does not do anything the equipment it means that the fault is generated by the system board, the solution is replace it.
Jan 08, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
