Question about X-Acto Model 41 Electric Pencil Sharpener
How do i repair an x-acto model 14 pencil sharpener
My x-acto quit running. Thought it was to cool down, but has been cooling over the weekend and still will not work. Gives a light humm sound but motor does not start.
I thought I got prime on the 25 when I opened the credit card. I went to order something on prime and it said I didn't have it
Sorry but that is between you and Amazon we have nothing to do with them..from what I read Prime is a costly thing to have .
Sep 29, 2015 | Office Equipment & Supplies
Pencil sharpener won't stop running
probably a piece of lead stuck on switch. Unplug unit, shine a flashlight into it and see if you see anything other than the sharpening head(s).
Apr 01, 2014 | X-Acto XActo School Pro Electric Pencil...
Crayon is stuck inside pencil sharpener
Hello, I need the model number of the pencil sharpner. You might go to bostitch and call support for help.
Jan 10, 2014 | Stanley Bostitch Electric Pencil Sharpener
Where can I buy a shavings receptacle replacement for my X-Acto School Pro Electric Pencil Sharpener Model 167X. Mine got dropped and broke.
This is a new answer for an old question. Just today, I emailed the Xacto company (contact us on their website) and they responded with " a courtesy replacement will be sent to the address below."
May 06, 2013 | X-Acto XActo School Pro Electric Pencil...
Won't sharpen end of pencil
Check for a broken piece of lead down in the sharpener by the rotary blades.
Dec 14, 2012 | Stanley BOSTITCH EPS11HC Quiet Sharp 8...
When I insert a pencil into my brand new school pro sharpener, the blades spin, but do not sharpen.
The website says to check and make sure its not jammed with pencil lead or something else. unplug it take the shavings bin out and flip it upside down so you can look into the sharpeners. Rotate them by hand till you can see the open side of the blade then use a unfolded paper clip and slide it in the path the pencil would usually take. This should knock anything loose the would be jammed in there. If it passes through to where you can see the point you should be clear. If you didn't dislodge anything or it still doesn't sharpen but the blades spin when you try to use the sharpener, then there is a tab that can get jammed back that needs to be in the foreword position. The tab is located where the tip of the pencil would point if it was actually being sharpened. if you run the paper clip through the machine (just like when trying to dislodge something) the tip of the clip will touch the tab. make sure its not jammed back (away from the opening/pencil) it should be as far forward as possible for the blades to engage. I hope this helps! This has been jammed many times by pencil shavings or gunk on my wife's (elementary school teacher) pencil sharpener.
Sep 22, 2011 | X-Acto XActo School Pro Electric Pencil...
X-Acto Model 41 Electric Pencil Sharpener Logo
Top X-Acto Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a X-Acto Office Equipment and Supply Expert? Answer questions, earn points and help others
