Question about Epson Stylus CX9400 Photo Printer
ATT u-verse phone which is voip and HP 6180 All in One
Just found out from HP digital phone line and analog line the fax operates on will probably mean no faxes geting through. Is there anything that will remediate this situation? Thank you.
  • Anonymous Feb 27, 2009
    fax is always busy
    President:
  • 2,692 Answers
Ask ATT if they have available a Digital to Antalog converter that can use for with your  fax machine.
Posted on Feb 17, 2009
What is ecm tx
ECM is basically error correction mode. Tx is transmission. If you're having trouble transmitting, lower the default speed to 14.4kps. Fax transmit best on analog phone lines. Digital lines will work, but unless you have a digital fax modem 14.4 is often the best you can hope for. If you're on a voice over ip max speed is 9600bps and it probably still won't work. Buy an analog phone adapter for VoIP. If you're still having transmission troubles turn off ECM.
May 02, 2014 | Canon FAXPHONE L80 Laser
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
We have the L 7680. Last week we changed from ATT dsl line with filter to ATT Uverse. They installed. With the change, our fax stopped working in/out. It reads as No Answer from outbound attempts and...
The Uverse service appears to be all digital - so any voice/phone channels are going to be VOIP....not real analog lines as you had before. So, you need to connect the HP fax to a phone line service. Did ATT provide you a phone number? (or perhaps 2 phone numbers) Then the fax should be connected to that line. If you are unsure, then connect a phone to the provided line and listen for dial tone. If you are connecting a fax to a VOIP line then a good suggestion is to drop the fax speed to 9600....this will provide more reliable connections. Hope this helps
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Recieve faxes problem in hp laserjet 3050
- cables properly connected
- analog or digital (DSL, VoIP, etc) phone line
- dedicated line?
- under fax setup, all faxes, turn error correction off
- under fax setup, all faxes, turn v.34 off
- test fax
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
Message Waiting Indicator (MWI) light stays on since VoIP
There maybe different MWI options available in the phone's set up menu on the base unit. If so, see if the different options perform differently. Your phones are probably set to "FSK" (frequency shift keying) for MWI but IIRC, U-Verse uses the "Stutter" option. Also, in addition to talking to the installer, call ATT tech support. If the problem is in the signalling they may now have programming options on their end to resolve it.
Apr 26, 2010 | Siemens Gigaset 8825 Cordless Phone
Slow down a HP 640fax machine for VOIP use
Can't be done. ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Oct 17, 2009 | HP 640 Inkjet Fax Machine
Hp j6400 fax over voip line error code 388
Fax machines are ANALOG devices, VOIP, Vonage etc are DIGITAL devices.. It won't work reliably
Oct 29, 2008 | Office Equipment & Supplies
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Epson Stylus CX9400 Photo Printer Logo
300 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
