Question about ECS HB06ML HearthRite Heater
Hearthrite hr30tn-1 wont sta lit
Sta Rite Max-E-Therm 400 does not fire and on the circuit board the LED11 and the U11 are lit
when cycling see if ignitor lites and gas valve open if none check safety circuit
May 31, 2017 | Sta Rite Pool & Spa
Heater won't stay lit
could be caused by many things. could be an flame sensor error, open saftey switch, stack flue error, etc look on back of circuit board and tell me what errors are lit up
Mar 08, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Hearthrite HR-15ML Propane Heater Malfunctioning
Could be dust build-up from the months of inactivity. Try taking a can of compressed air and blow into the ignitor and flame port. If dust is the problem, that should clear it out.
Dec 10, 2012 | Empire Comfort Systems Empire 15,000 BTU...
Thermo cuppler wont sta lit after 3 times!
Replace it, its bad. Remove the old one, take it with you when you go to the supply/hardware store. Be sure to purchase one of the same style and length.
Apr 17, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light wont stay lit when button is released
If the thermocouple is being well covered by the pilot flame, then it sounds like the thermocouple or thermopile is bad (a thermocouple and thermopile both perform the same way, but are entirely different devices. I am unsure which yours has.
Also, make sure all connections from the t-couple of generator are snug tight to the gas valve. There may also be a temperature sensor that has tripped that prevents the pilot from remaining lit. Follow the thermocouple/thermopile tubing to locate any inline sensors that may be open, preventing the signal reaching the gas valve.
Let me know if I can help more. I have not been able to find any information on this specific unit, so will have to speak in general about what to look for.
Dec 16, 2009 | Empire ECS HearthRite HB20T Heater
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Dec 17, 2008 | Empire ECS HB06M HearthRite Heater
ECS HB06ML HearthRite Heater Logo
37 people viewed this question
Top ECS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an ECS Heating and Cooling Expert? Answer questions, earn points and help others
