Question about Sewing Machines
Floral delights jodie johnson details how to put together
Not enough information on how to put together
I thought you had a pattern for a tissue box [crochet] the long box , floral preferred
You need to search the internet specifically for what you seek. We don't offer products or patterns.
Aug 23, 2017 | Sewing Machines
Reset to fabric
Please provide more information. This does not give us enough detail to address your question.
Oct 11, 2016 | Sewing Machines
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
Year of manufacture machine serial number v/740881/693
not enough information
you have to supply make model and any other details that you can find
Oct 30, 2015 | Sewing Machines
Will not pick up the metal floral pics
Excuse me? I'm sorry but your question makes no sense. Please elaborate.
Dec 02, 2012 | Sewing Machines
Sewing instructions for simplicity pattern 3553
if you copy this link into your browser window you will see the pattern details including Instructions, its a tab down the screen under the image, "Fabric and Notions" "instructions" and "size chart"
http://www.sewingpatterns.com/sub_item.php?item_num=3553SIM&model=%&new_category=search&view=gallery&brand=&category=search&pageGoto=0&pageFormat=3'186'186&pageCount=18&search=3553&return=yes
Looks pretty easy, sew the inside leg seam of each trouser leg together,
then sew the ****** seam and do the waistband.
Dec 18, 2011 | Sewing Machines
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
Puckering material
You may need to utilize backing to correct the puckering, and/or if possible, also sew on the bias. I do not have enough information to interpret the origin/cause of the "noise". Please click on the URL below for helpful information in correcting typical stitching and machine woes....good luck my friend: http://www.fixya.com/support/t162553-underthread_going_crazy
Jul 26, 2007 | Toyota SE-06 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
