Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
KEY STUCK IGNITION KEY WONT COME OUT
*** Always be gentle when wiggling the key or rocking the steering wheel
Wiggle the steering wheel back and forth while trying to pull out the key. Be gentle, otherwise the key could break off in the ignition. If this does not work, try the next option.
Read more: How to Remove a Key Stuck in an Auto Ignition ' eHow.com http://www.ehow.com/how_7644826_remove-key-stuck-auto-ignition.html#ixzz2HxwUux9u
Jack up the front of the car until the wheels just leave the ground. This takes the weight off the front wheels and gives the steering column a little more room to move. Wiggle the steering wheel and try to pull the key out. If the key remains stuck, try the next idea while the car is jacked up.
Spray some Teflon dry lube into the ignition switch around the key. Just a couple of quick squirts will do the trick. Use the dental pick to actuate the pins in the ignition cylinder. This will hopefully lube the pins and lock enough so that the key can be wiggled out. If the key is still good and stuck, there are two last things to try before having to call a repair shop or locksmith. Lower the car back to the ground before moving on to the next idea.
Fill a zip-type sandwich bag half full with ice. If the cubes are large, crush them to make the bag easier to handle. Wrap the ice bag around the head of the key. The idea here is to get the metal of the key to contract because of the cold, so this may take up to fifteen minutes before it is effective. Try to wiggle the key out. If the key is still stuck, it is time to add heat.
Turn on a hair dryer and direct the air toward the ignition cylinder, while keeping the ice on the key itself. Heat will expand the cylinder, while the ice works on the key. Do this for fifteen minutes and try wiggling the key out.
*** Always be gentle when wiggling the key or rocking the steering wheel.
Posted on Jan 14, 2013
I cant start the car the key wont turn in ignition
Last time i had this problem, my car wasnt all the way in park, so what i would try is:
1: apply the break
2: push up on the gear shift, to make sure its in park.( if you can move the gear out of park, move it all the way to drive 2, then back to park.
3: try the key again
Aug 01, 2016 | 1995-1996 Saab 900s Convertible Top Cover
Key wont turn in ignition
If another key works look for a small difference between keys. Sometimes a key is cut high or low. If no key works in the ignition then it could be the tumbler.
Dec 29, 2013 | Mazda Protege Cars & Trucks
Key wont turn in ignition. Dont want to hear the key is bent. Tried everything to get it to turn, but wont. It happened earlier today and after 20 minutes of giggling the key it finally turned over. ...
The problem can only be one of three things. Steering column, ignition or key. When there is tension on the steering wheel it will prevent the key from turning. If the linkage in your ignition is bad it will prevent it from turning. If your key looks worn or marred (it doesn't always have to be bent) it wont turn.
Jun 15, 2011 | 2000 Mitsubishi Montero Sport
Ignition key wont turn
is it correct key? key and ignition barrel could be worn wiggle key around in ignition while turning? gently but fast wiggling.try lube in key slot also.
if not replace barrel and key
May 31, 2009 | 1995 Toyota Camry
1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Dec 23, 2008 | 1998 Buick LeSabre
Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011 Logo
351 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
