Question about GE Spacemaker JVM1640SJ Microwave Oven
What is the wattage of the GE model JE1860GB003
GE MICROWAVE OVEN JE1860GB003 WON'T START. CHECKED POWER OUTLET WAS OK. BUT NO POWER TO UNIT
Probably the internal ceramic fuse.Danger High Voltage...I change mine and it started working again..It's not that hard to do...But you have to take the cover off....Google how to do it
Aug 14, 2017 | GE Microwave Ovens
GE microwave model PVM1790DR1BB what is the wattage.
Hi Augusto
According to the manufacturer, the wattage is 1000.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PVM1790DRBB&omni_key=FBRRApp
In case you need the owners manual, see the link below.
Hope this helps you out.
-Steve
PVM1790DR1BB GE MICROWAVE Manual
Mar 17, 2015 | GE Microwave Ovens
What is the wattage output of my GE Spacemaker Microwave model JVM1850SH02
The JVM1850SH microwave has a maximum power output of 1100W.
I hope this helps.
(The final two digits are not critical for the microwave's specifications.)
Mar 06, 2015 | GE Microwave Ovens
Can ou please tell me wha the wattage is on a 1995 GE pscesaver Mirowave Model #JVM240wv and ser# of FM924649S?
The owner's manual (here) says on the front page that it is a 850W model.
If you need repair, see this link for more tips, or for a "drop-in" replacement, see GE support.
Oct 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Can you please tell me the wattage on a 1995 GE Spacemaker microwave oven Model JVM240wv? Ser# is FM924649s....thanks..
Can not determine the wattage of the microwave we bought. It is a GE microwave model #JNM1851DM4BB
There is no reference to this model on the GE website, but have a look at this webpage:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?Name=340104_jvm1851bhchshwh_r3.pdf&RequestType=PDF
The wattage of this model JVM1851 is 1100W.
If the model is a counter top unit, you can check whether there is a plate at the back of the oven with the wattage on it.
Feb 26, 2011 | Microwave Ovens
Microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Jul 10, 2010 | GE JES735WJ Microwave Oven
What is the proper wattage for the replacement over range bulbs? model #MA9698175 thanks
That's not a correct GE model number, but you can find handy exploded views and order parts by model number here.
You can also download GE owner's manuals and installation instructions here.
Sep 26, 2009 | GE Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
27 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
