Question about Refrigerators
My mm14ge had 134a leack fix leak perforn vacun add 12oz ofautozone 134a compressor running all fans running still blowing hot air
  • 159 Answers
SOURCE: Fridge isn't cold
First thing I would check is the evaporator fan in the freezer to make sure its working. About the copper lines, one should be cold to the touch and the other should be hot. if both are cold your compressor may be locked up. Or if its a whirlpool build unit I would also check to make sure the relay on the ompressor is good.Pull it off the compressor and shake it. If you hear like a lot of little pebles shaking in it its bad and need replacement. that was a common problem with some whirlpool units. If that is good remove the back of the freezer and check the evaporator coils to see if there is a frost pattern on it. If not your compressor like I said may be bad or you have a refrigerant leak and there is no more gas in it. Good luck
Posted on Jul 19, 2007
jumptrout51
  • 3361 Answers
SOURCE: My Beverage air model # mm14ge blows hot air.
Check the start relay and capacitor on the compressor.
Check the fan motor on the compressor.
Posted on Mar 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: Refigerator is blowing warm air
EITHER THE FLAP THAT SEPERATES COLD AIR FROM FRIDGE TO FREEZER IS CLOSED
OR
COILS ARE CAKED WITH DUST
OR
FREON IS WORN OUT
Posted on Mar 31, 2009
  • 1250 Answers
SOURCE: GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
Posted on May 09, 2009
  • 415 Answers
SOURCE: fans blowing and moving air -compressor very hot -no cold air
un plug the unit and get a new compressor start relay can be purchased at a appliance parts store
Posted on Aug 26, 2009
2003 ford focus no cool air is blowing out. Could it be the evaporation cord?
Make sure your blower fan is turned on and is blowing air. When you push your a/c button the yellow light should come on. If it is not blowing cool, it could be several things. Low on 134a or the control that has the a/c button on it could be bad or blown fuse, bad compressor, etc. If the air is cool but not cold the 134A is low. If it is still blowing hot, check and make sure that the clutch on the compressor is locked in. It most likely is not. Check ac fuses and ac relay, if they are good, check the 134a ,if low, refill it. This should fix it. Remember that if the a/c clutch is not locking in, you cannot add 134a because of no circulation.On some vehicles, if it is completely out of 134a, the relay will not trip and you will have to bypass the relay to provide power to the compressor to fill it. If you do all of these and it still does not work, you will need to take it to a professional. If you need to, reply back and I will give you more possibilities.(I think that you mean evaporator coil)
Jun 03, 2014 | 2001 Ford Focus
My 2003 jeep liberty's air conditioner blows hot
Probably, to be sure make sure the compressor is coming on. With the engine running turn on the ac and watch the rpms, they should drop for a second if the compressor is coming on. If so you just need to recharge, the refrigerant is R-134a, which you can get from your local parts store along with the kit needed to charge it. The kit will come with detailed instructions and is a pretty easy job.
Jun 10, 2011 | 2003 Jeep Liberty
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Sep 27, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
A/c not working blows hot air add 134a need help 99 f150 4.2 v6
Before you add freon to measure how much freon is clucht checks if the compressor is activated when you connect the air conditioner if the clucht not activated and have a good pressure in the system looks at low pressure switch that goes in the drier and that very often these are damaged, you also have to check the fuse and relay the compresor.Thanks
Mar 28, 2010 | 2004 Ford F150
The air conditioner blows hot air. Is there a way I can test for a leak in the system or does this require a technician? I am thinking it's not a compressor because it is blowing.
Apart from doing a low side pressure check, you can try to recharge the system yourself with a refill kit that's readily available at most auto parts stores. If you're concerned about a leak, also get a can of R-134A with the UV dye that will show any leaking components.
RECHARGING AC SYSTEM
  1. Turn the truck on and turn AC on HIGH
  2. Locate the low side AC line (will have a valve and cap similar to the cap on a tire)
  3. Insert the oil or R-134A can to the hose (Do not turn the screw to puncture the can yet)
  4. Insert the other end of the refill hose to the low side valve
  5. Puncture the R-134A can with the screw on the refill hose
  6. You should feel the system suction the refrigerant out of the can
  7. Check for frost on the AC lines and the air blowing inside the truck
  8. If frost develops and the air is cold, you've successfully recharged the system and disconnect the refill hose. DO NOT ADD MORE REFRIGERANT...overcharging the system will damage your compressor and will be less effective
Hopefully this answers your question and you're able to get your AC working again. Best of luck.
Greg
Jul 13, 2009 | 1996 GMC Sierra
My 1996 Lincoln Town car heater works but you cannot control the temperature and the air conditioner blows out hot air when turned on.What could be the cause of this problem?
To fix the AC unit which blows hot air all the time. Seems like you have a small leak in the system or the AC compressor has gone out. Suggest you try recharging the unit. Make sure you have the correct R-22 or 134A freeon. If this work for a few days then have the leak fixed, if this doesn't work replace the compressor. Check Ebay for the compressor i obtained one for $100.00. Cost $450 at Auto Zone.
Jun 26, 2009 | 1996 Lincoln Town Car
1998 Chevy Blazer Blowing Hot Air and Compressor Not Engaging
You would be low on 134a. To put refegerant in an a/c system you need to pull a vaccume on the system. Any air in there it will not work. It would be worth the money to have some one do it. But I'd look at the compressor case halfs and see if they are leaking before having it charged. You could fix that yourself and pay some one to charge it, if they are leaking.
Jun 19, 2009 | 1999 Chevrolet Blazer
My Beverage air model # mm14ge blows hot air. why, and what must i do to fix this please.....thank You
Mar 19, 2009 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
