This Homles humidifier leaks water out by the morning. I was wondering how to stop that from happening. Thanks!
    Genius:
  • 1,669 Answers
Check the seal between the reservoir and the base. Do you see water on the floor under the machine? If so, put the whole machine on a large flat tray with a layer of newspaper on it and periodically lift it to see where the water is draining from. Chances are, it is from a hose that carries from the reservoir to the boiling unit.
Posted on Jan 14, 2013
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
Water coming into humidifier has recently begun to leak out from connection to the discharge tube.
THE WATER CONNECTION TO THE INPUT OF THE HUMIDIFIER IS LEAKING? - -IF THIS IS THE CASE, SHUT OF THE WATER SUPPLY TO THE HUMIDFIER, UN-SCREW THE INPUT CONNECTION, USING SOME PLUMBING WHITE CONNECTION TAPE, WRAP A COUPLE OF TURNS UNTO THE THREADS, RE-CONNECT AND TURN ON THE WATER SUPPLY. IT SHOULD STOP LEAKING.
IF ITS THE OUTPUT OF THE HUMIDIFIER OR DISCHARGE TUBE, THIS IS NOT UNDER ANY WATER PRESSURE LIKE THE INPUT IS, AND IT IS POSSIBLE THAT THE HOSE MAY BEJUST LOOSE OR CRACKED AT THE HUMIDIFIER. CUT OFF THE HOSE AND RE-ATTACHING WILL WORK OR MAY EVEN NEED A NEW HOSE.
Feb 20, 2011 | Aprilaire 700 Humidifier
Leftover water in the base was hot in the morning
If there is not much leftover water, you don't have to worry much about it. However, if the leftover water is
somewhat flooding the area where it was located, it is a
different story, there is a leak and it must be corrected.
Check for leaks in the water container, so that operates
normally. Hope this will help you.
Jan 10, 2010 | Kaz 5520B Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Apr 17, 2009 | Honeywell HE365 Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Water dripping from unit
if the water panel needs to be replaced , this can happen. instead of going through the panel , water will run on the outside of the panel and drip through the seems on the humidifier cover. make sure the plastic hose that goes into the water panel is inserted into the water panel.
Dec 27, 2007 | Aprilaire 700 Humidifier
Humidifier leaks
My Air-O-Swiss U7142 has a leak from the very bottom. I found that as long as the water flows on to the "pan" that evaporizes the water, the water will come out from the bottom. Does anybody know how to fix this?
Jan 18, 2006 | Honeywell HCM530 Humidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
