Frigidaire washing machine model ftf214es won t spin
It does not spin fast
  • 220 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
If you want to take the time, I just replaced my drum bearings and seal for $62.00. No really any special tools needed. My model showed the bearings were not sold seperately and you had to buy the complete tub half, but when you take it apart, you can knock out the bearings and buy them online or at a bearing house. I have a seal part number also.
If I remember right the bearing part numbers are 6306-2RS and 6307-2RS (1 each) and the seal is a 40mmX80mmX10mm thick. Make sure you get the -2RS bearings because they are sealed. The ones that came out of mine are shielded bearings ( -Z ) and they will not resist moisture if the seal shaft seal fails.
Most AutoZones have seal and bearing drivers you can "borrow". They really help during installation so you don't deform the seal or damage the new bearings.
Any good bearing house should be able to macth on up or if you post back I can give you the exact number. I think most brands of front washer use the same bearings, but you may want to take yours apart before you buy.
Worst case the junk yard doesn't care if it comes in pieces or as one piece. Give it a try.
Not sure you will want to get this involved, but its not really too bad of a job.
Posted on Dec 31, 2008
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
SOURCE: My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Posted on Feb 14, 2010
Why won't my Front load washing machine spin fast after draining?
spins but not fast? a slipping clutch or brake problems
Jul 15, 2014 | Frigidaire Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Washing machine won't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 14, 2011 | Frigidaire Washing Machines
My front load washer will not spin fast during the spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 24, 2010 | Frigidaire Washing Machines
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not go into fast spin cycle
SOUNDS LIKE YOU MAY HAVE TTO REPLACE YOUR BELT ON YOUR WASHER. I AM NOT A MECHANIC, BUT I THINK THIS WILL HELP.
May 13, 2009 | Frigidaire Washing Machines
Frigidaire washer
spin the option button around fast several times unplug it and try it again ......occasionally the connections inside get dirty or somethin it worked for me.... spin it fast!!!! cleans the connections
Oct 25, 2008 | Frigidaire Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
