Question about Music
Boss me-5 schematic - Music
  • 110 Answers
Here you go! BOSS ME-5 Schematic.
Posted on Jan 14, 2013
Need schematic for Boss BR 600 digital recorder. My power input has failed. need value and direction of diode to replace Q47 chip.
To be sure you need a schematic. You can actually take a look at it to see if is labeled or check polarity with a meter.
Dec 04, 2014 | Roland BOSS BR 600 8 track portable...
How do I connect my Boss CE-5 pedal for stereo?
Quite simply connect each output to its own guitar amp or use two mono or one stereo DI box and connect to stereo PA.
Sep 25, 2014 | Roland Boss CE-5 Chorus Ensemble CE5...
How do plug your guitar into the boss rv3 which jacks
Plug your guitar into the input and a cord from one or both outputs to the inputs of whatever you are using. Meant to be run in stereo for best sound. Two guitar amps?
Sep 24, 2010 | BOSS AUDIO SYSTEMS Boss Rv 5 Digital...
Need operating manual for BOSS Dr. Rhythm Section DR-5
Here is one link:http://cms.rolandus.com/assets/media/pdf/dr5_turbo.pdf Here is more:http://www.rubiconsystems.com/paul/dr5faq.htm
Jun 28, 2010 | Boss Music
Boss DD3 - LED switches ON but the signal remains dry.
Have you tried a new battery?
If you have experience with electronics then open it up and start testing all the components with a digital multimeter to find the failed component(s).
Unfortunately the newer DD3's are harder to fix then they once were. There is no place to point you other than just to start testing everything. Hard to say what has failed. The signal into the input of the circuit may simply be shorting to the output. Maybe the switch or switching circuit has a fault.
Here is the schematic as a reference: http://www.8bitsindgenug.net/boss_dd2.png
Dec 29, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Pedal inputs messed up? just buzzes, no sound!
Here is the schematic:http://www.godiksennet.com/images/sch/NS2.jpg Try testing or replacing Q1 first.
Nov 25, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
My boss dd-3 pedal only works with a 9v battery. When I hook it up to the 9v apaptor, (a boss) it freaks out and does nothing. Can you help? Everything seems solid. the jack doesn't wiggle or anything.
You will have to test the adapter with a volt ohm meter to make sure it is putting out the proper voltage. It should be as close to 9 volts as possible. Also make sure that thehole in the plug is negative and the outside is positive. Is it the right adapter? I don't have a schematic for this model but www.schematicheaven.com has one for a DD-2. Hopefully they haven't changed too much. If you decide to repair it yourself, check the adapter first then check for a bad solder joint where the adapter plug is soldered to the circuit board. Hope this helps somewhat.
May 14, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Music Logo
157 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
