Question about Jensen VM9510 Car DVD Player
Jensen vm9511ts (Video Feed)
I have a issue but not with the parking brake, that was pretty easy all I did was I I added a kill switch and grounded the wire. Now my issue is that apart from having my screen in the front I also have 2 screens in my headrest . Now I had tried this in-dash in 2 different casr and the screens in the back dont seem to work. They come on when they please and turn off whenever they feel like it (I power them on and I get a blue screen and the video feed will just come and go, sometime it will last for a while and sometimes just a minute). Anyone know what might be wrong with them..? Now on another note I used to have a different in-dash and my back screens worked fine..???
    Scholar:
  • 116 Answers
I know that the Jensen has a "Dual Zone" setup in the menu settings. Make sure that you have it set right. Make sure nalso that you are using a MONITOR OUT RCA from the Jensen, not a source input on the deck.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Emergency parking wire for jensen vm9311ts
your parking brake wire from radio is pink .
1 take a toggle switch 12 volt dc and 20 amps
2 take the pink wire attach the wire to the top terminal of the toggle switch
3 take the bottom terminal and attach a black wire to it and ground the other side of wire you must have a good ground ...
then once this is done test the switch turn on dvd it a video and flip the switch up and down a couple of time to simulate the parking brake and the video should work ...
if this doesnt work email me and ill give you the relay diagram to connect a relay inline to activate video but im pretty sure it will ...
http://www.tintingbyfredjohnson.com go here to my online store and email me from contacts
Dec 28, 2010 | Jensen Car Audio & Video
How do i get my tv to work
did you put a toggle switch in between the wiring ?
Mar 23, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Video wont play
Go to www.google.com then type JENSEN CODE choose the first one on the top.
Mar 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Make is jensen vm9311TS
HI,
I'll let you know if the codes are available..
Jun 03, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9511TS
did you hook it up? If so do you have all the wires for the multimedia pushed in. If you payed someone have them look at it.
Mar 18, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
77 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
