Question about Xerox WorkCentre 3220 All-In-One Laser Printer
Xerox worke centre 3220 nvm reset - Xerox WorkCentre 3220 All-In-One Laser Printer
4 Suggested Answers
  • 62 Answers
SOURCE: xerox dc 12 mailbox finisher
its plug and play...you dont need to change anything
Posted on Nov 19, 2008
  • 62 Answers
SOURCE: mailbox ,finisher xerox dc12
i take you have a mailbox finisher. If so the finisher is plug and play with the dc12
Posted on Feb 20, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
Xerox work centre 5865 printing depth NVM values
If the machine just started printing light it could be a problem with the developer unit or charge roller or hvps. You can change the change grid voltage manually.
press and hold the 0 button for 5 seconds, while still holding the 0 buttom press the Start button the enter password of 6789 and press enter. Go to adjustments tab, then nvm read/write, go to chain 791-007 and decrease the value by increments of 25.
Apr 12, 2016 | Xerox Office Equipment & Supplies
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
004-361 error code in xerox 7345
Hi
Xerox Werk Centre 7428 Tray 2 NVM Read / Write Chain-Linc & Current Value
Feb 03, 2013 | Xerox WorkCentre 7328 Multifunction laser...
How to reset NVM in xerox workcentre 5020
how to set xerox work center 5020 sound problem
Jul 11, 2012 | Xerox Office Equipment & Supplies
Xerox work center 5020dn service manual available here
Pl give the solution of N9 code in Xerox 5020Dn m/c.We have reset the NVM
Aug 19, 2010 | Xerox DocuColor 12 Printer
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
Work center 220 xerox
Either remove or short out the NVM battery.
That should reset it.
Jan 21, 2008 | Xerox Phaser 8400 Laser Printer
Xerox WorkCentre 3220 All-In-One Laser Printer Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
