Question about Dryers
Dont know what coulor wires go to what for the heater
Taken it apart to replace the motor putting it back together dont know what colour goes to what for the heater
  • Dryers Master
  • 8,220 Answers
The fat red wires go to the heater in most cases. What is you model number? Can you post pictures? All dryers ain't the same. your ques needs clarification.
Posted on Jan 14, 2013
  • 1028 Answers
SOURCE: Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Posted on Sep 13, 2008
erpaalai
  • 999 Answers
SOURCE: dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
Posted on Jun 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Posted on Sep 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I need help putting my dryer back together
Here is a couple of websites that shows the breakdown and parts of dryers, maybe they will have your model to help show where the two springs go.
http://www.appliancepartspros.com/index.aspx
You could also try this website.
http://www.partselect.com/
Good luck,
I hope this helps
Posted on Oct 06, 2009
  • 8404 Answers
SOURCE: older maytag dryer: rewiring help
If it is a usual door switch, it is simply OPEN or CLOSED (the switch im talking about ... not the door.) Translation, it doesnt make any difference. When the wires are connected in the switch, the machine thinks the door is closed. When they are apart, the machine thinks the door is open.
Make sense?
(Maybe)
Two wires one switch it is a 'switch leg'
If I read this incorrectly, please tell me. (I answer the belt question all the time ... I usually remind people to be careful of the door switch ... )
Thanks for using FixYa.com
Positive comments always welcome.
a
Posted on Oct 28, 2009
How to replace an Electrolux Z331 motor?
Did you follow how motor was taken apart? If not, hopefully color goes with color.
May 06, 2014 | Electrolux Vacuums
Replace motor
green is always ground. white or gray is always neutral. and black, red always hot. without know what make,model machine your working on this is best info i can give.
Jan 14, 2013 | Vacuums
Dryer door switch assembly. how do I put it back together
All the terminals should be different in size with the big terminal wire being common which goes in the middle the other 2 wires make the light come on and make the motor go so if you get em backwards she will run with the door open and the light will come on with the door closed..
Aug 29, 2012 | Maytag Dryers
MY SHOP RIDER JERKS WHILE I AM MOVING,TOOK OUT BRUSH ON SIDE OF MOTOR LOOKS FINE.I THEN TOOK PART OFF END OF MOTOR HELD BY THREE SCREWS,THEN UNDONE TWO LONG SCREWS PULLED MAGNETISED MOTOR APART,CLEANED...
Hello,please rate me for info with thumbs up 1 to 4.im disabled myself & i do this cause i care not for money.Please dont do anything else,you said you checked 1 brush.there are 2 & they should be a certain length plus,should slide in & out easy with the aid of the spring in each 1.there is a set out proceedure when searching for faultsWhat you need is to visit :www.alldatasheet.com. Type in -troubleshooter_2007 SHOPRIDER.pdf .You need to download this to be read in Adobe Reader as a PDF File you can save it on Adobe Reader & or print for future Ref.MAYBE PUT IT IN A POLYTHENE SLEVE FOLDER.tHAT WILL TELL YA ALL YOU WANNA KNOW.Or type in shoprider.com & b4 actually going into it ur search engine will give ya a load of links to click on look for the:PDF File in Adobe Reader.take care & b4 i forget,heres a tip anything you take on to repair,please for you take a pic with a mobile so you know exactly what was where,Colin.
Aug 03, 2010 | Health & Beauty
Can't unlock my wheel! I have taken apart the wheel and put it back on and still the wheels will NOT unlock. How do I fix this?
I have taken my stroller (evenflo # 4331N5 and dont know where the screws go to put it back together
Mar 14, 2010 | Quinny Buzz Jogger
Putting on belt
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
