Question about Seagate Computers & Internet
What's your problem?hi my hard drive is not working the green light at the front is flashing and it is not up on my pc any more can you help me please
  • Seagate Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 15, 2013
dodgecharger
  • 254 Answers
SOURCE: Maxtor external hard drive
I'd first check the unit on a second computer. If it does the same thing, then you likely have a defective unit
Posted on Sep 12, 2007
SOURCE: Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
Posted on Apr 28, 2009
  • 29 Answers
SOURCE: Help! Western Digital My Book Does Not Work
possibly the firmware is corrupted,u need some tools to repair it.or go 2 the professional dr company
Posted on May 19, 2009
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
bob_computer
  • 3153 Answers
SOURCE: When I supply power to the hard drive, the green light flashes.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
1 tb external hard drive which is not been recognized
ops fail if you have soft info on hdd and you need it nesesery take hime to maitenuse to help you for recovery but these very expensive
Apr 24, 2013 | Computers & Internet
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
My Western Digital 1 TB External Hard Drive isn't working. The light just keeps flashing, that's it. Help!
Was it working before with the same computer ? Try with a PC is you can, maybe the drive was has filesystem that mac cannot see by default (like NTFS).
Jun 21, 2012 | Western Digital My Book Essential 1TB...
When I plug my Cruzer U3 Micro 2.0GB flash drive into my USB port the light flashes once and then remains off. The PC doens't recognize that there is anything connected. This flash drive was working...
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Sep 08, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Feb 15, 2009 | Western Digital 500GB My Book World...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Hard Drive
That little "red flashing light" on the front of your computer case is the HDD activity LED. When it flashes it indicates that there's hard drive activity. No, you do not need to worry about if flashing.
Thanx for using fixya,
Hope my info helps.
Sep 26, 2008 | Acer Aspire™ T180 PC Desktop
Drive only flashed green light
hi ,
If this drive happens to be one of the recent NEC/Optiarc drives then the drive is stuck in safe mode.
At (post boot) repeatedly press the eject button and the drawer should open and recover the drive. (only relevant to NEC drives 357x/457x or newer).
Sep 05, 2008 | Cavalry Storage CAND37300 300 GB USB 2.0...
Computers & Internet Logo
204 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
