Question about Megger VF2 Voltage Detector Pen with LED Flashlight
How do i replace the batteries in a meggervf2 volt finder/flashlight
Need replacement bulb for stink free stink finder
does this actually work? seems like a weird product. but alas without a replacement bulb you might not be able to tell me. have you tried the vendor where you purchased the questionably legit light? i can't see them for say anywhere obvious. but with the prices online of these things the bulb is probably going to cost you as much if not more than the entire product.
Mar 16, 2014 | Stink Free Stink-Finder Ultra-Violet Light...
BATTERIES FOR MODEL JXSL10
Just take battery out and match it with the same type-12 volt sealed lead acid battery-I think mine cost 30$ online. I haven't had luck finding a replacement bulb. That is what my spotlight needs!
Dec 03, 2013 | Jeep Heavy Duty Jxsl10 Rechargeable...
Need a charger for maxim combo drill set 18 volt drill, saw, flashlight
Go to support on the tool manufacturers website. You should be able to click on a parts finder and type in your model number and find the charger. murf427
Aug 03, 2012 | Drills
When I turn on my Flip Video, it just goes to a black screen.
Most often it's the batteries. Many people will test a set of batteries in one of two ways,
1) With a volt meter and each battery reads 1.5 volts (or close to it)
2) Or in a flashlight and assume that if the flashlight is bright that the batteries will work in the Flip.
The Flip draws current that a volt meter does not check and it draws much more current then a flashlight needs to operate. So that is my first suggestion is to buy fresh batteries and try that.
Nov 24, 2010 | Pure Digital Flip Video Ultra Camcorder
Not charging?
Start out by checking the power transformer with a volt meter. It should read 13.8 volts. If you do not have volt meter, after the transformer has been plugged in for a few minutes, it should feel warm. Another possibility, which is more likely the problem, is that a battery or battery unit has gone bad and needs replacing.
Good Luck!
Jul 20, 2010 | MagLite RX3019 Rechargeable Flashlight...
® XRF Xenon Rechargeable Flashlight: Where can we find the batteries for Xenon Cyclops ...
I am not familiar with that particular model flashlight. Most of the Cuclops flashlights use the 3.0 Volt CR123 Battery. However, here is the URL for Cyclops Solutions website. www.cyclopssolutions.com/index.html
May 15, 2010 | Cyclops ® XRF Xenon Rechargeable...
Charger is putting out 13.7 volts but battery does not take a charge
If its the right charger, and connected correctly, then it is probably just time to replace the battery. Try checking out http://www.batteryinternational.com/flashlight-batteries-streamlite---maglite.html for a replacement flashlight battery. Also, I'm not sure exactly what you mean by saying the charger is putting out 13.7 volts, but make sure you aren't using a charger that is too powerful, that can destroy the battery. Check out http://www.batteryinternational.com/battery-chargers-6-volt-battery-chargers.html. You shouldn't use a charger any larger than that. Hope that helps
Jul 10, 2009 | Vector 3 Million Candlepower Rechargeable...
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Megger VF2 Voltage Detector Pen with LED Flashlight Logo
123 people viewed this question
Top Megger Measuring Tools & Sensors Experts
Vuk B
Bill Boyd
ka4iup
ka4iup
Are you a Megger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
