Question about HP Pavilion a410n (DQ174A#ABA) PC Desktop
If my hp a410n pc has power, why wont the monitor come on
Trying to get an answer to having my acer monitor working with a410n pc
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Posted on Jan 14, 2013
Desk top power supply
It's not likely a power supply issue. I assume that you've tested the monitor and keyboard on another computer to confirm that they're functioning properly. The power button LED should flash a number of times indicating what the issue is.
That's likely to be a motherboard issue over a power supply issue. Unplug the computer, then pop off the side and ensure that all internal connections are secure. I always unplug and then plug back in.
If that doesn't do the trick, see the following troubleshooting guide:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph06739&lc=en&product=388428&tmp_track_link=ot_search#N105
Jan 29, 2014 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Cannot get the Fn-F5 to work on Acer AspireOne
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 10, 2011 | Acer Aspire One PC Notebook
My power button for my HP a410n desk top flashes and beeps when I try to turn it on. I removed the side panel, checked the memory stick to make sure it wasn't loose, put it in the second slot, and checked...
It can be an issue with the motherboard or the SMPS(power supply unit)...
You can remove the 24pin power cable plugged in the mother board and you can plug it back...
also try to remove the cmos battery and place it back in the motherboard...
The data that is stored on the Hard disk will never get erased, so you need not worry about your data...!
Feb 06, 2011 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
My acer al1914 wont power on... was working fine,
The usual suspects, blown fuse, blown capacitors, bad solder joints. Any of this conditions could be your problem.
Jul 16, 2010 | Acer AL1914 19" LCD Monitor
When i reboted my pc i simply wont come back on. The lights are on the fan is working the cd drive can be opend and closed. The monitor is ok. When i turn it on theirs no beep it just wont power up
Hello, I have the same problem as you. The answer is faulty Motherboard. If you have recently bought this, return it, else you must find a replacement board.
May 21, 2010 | Acer Aspire M1640 Refurbished Intel...
Wirless keyboard and mouse and monitor do not work.
try takeing the ram cards and clock battery out and unplug the tower from the wall wait 1-5 min then plug everything back in this has worked for me several times on several different computers not sure it will help you but its worth a try
Dec 19, 2009 | HP Computers & Internet
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
Oct 18, 2009 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Jun 23, 2008 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion a410n (DQ174A#ABA) PC Desktop Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
