Question about Motorsports
Replacing 2007 dodge charger ,02 sensor - Motorsports
  • John Wardlaw
    John Wardlaw Jan 16, 2013
    If you change out your factory exhaust, even just the headers! You will have problems with o2 sensors and other false readings. You must do a complete exhaust and then have your computer adjusted for new equipment added. LIve and Learn, not the old school street cars of my youth! Computer Controlled!!!
    Genius:
  • 1,669 Answers
The O2 sensor is on the exhaust pipe under the firewall and just before the catalytic converter. It has a wire on it that you need to be careful when you remove it. The sensor itself is screwed into the welded fitting on the exhaust manifold. You should use some liquid rust penetrating fluid (from the auto supply store) to help break it loose....tap the area to get the penetrating fluid in the threads. Use a socket of the appropriate size to turn it out...pop the new one in, connect the wire...
Posted on Jan 14, 2013
I have a 2007 Dodge Dourango and I have a check engine light the code of the car is p013c can anyone tell me what the code means.
Oxygen sensor slow response. Have the 02 sensor data scanned to determine what sensor may be causing the code. I have come across several dodge/chrysler models that required PCM replacement to correct this issue after replacing 02 sensors didn't correct the problem
Mar 17, 2016 | Dodge Cars & Trucks
PO137 dodge charger 2007 error code
Could be the bank 1 sensor 2 O2 sensor. But if you have an exhaust leak between the catalytic converter and the O2 sensor. Fix that first.
Mar 23, 2015 | Dodge Cars & Trucks
How to replace the safety switch under the gear shift in 2007 dodge charger
remove the shifter handle and remove solenoid and replace it with a new one solenoid is on the shifter bracket it self. and its easy to replace
Jun 09, 2012 | 2007 Dodge Charger SRT8 Sedan
Where is the egr sensor on 2007 dodge charger 2.7v6
2.7 engine? passenger side behind head with egr assy, (2 bolts )
Mar 26, 2012 | 2007 Dodge Charger SRT8 Sedan
I ordered BBK full length headers for my 2007 SRT8 6.1L Hemi Charger. Will they bolt up to OEM specs and have 02 sensor slots just as the stock headers do. Do I need to modify anything or get additional...
Should bolt to the head the same maybe go to studs in engine if possible. The O2 sensor needs to be inthe same distance fromthe head as before. If the sensor area needs to be removed from your system to put in the headers then drill a hole in the collector area and weld in a nut, then screw in the sensor as before
Jun 07, 2010 | 2007 Dodge Charger SRT8 Sedan
Oil light blinks and oil is at the max in my 07 dogdge charger
oil light normally blinks for 2 reason. low oil pressure or low oil level. if the level is good and since its a 2007 i would hope that it was getting pressure. so its prolly the sensor. you can either remove the sensor and have someone check it. electrician hopefully. or you can just replace it
Mar 20, 2009 | 2007 Dodge Charger SRT8 Sedan
Motorsports Logo
48 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
