Question about Texas Instruments TI-84 Plus Calculator
Where is the DEG button - Texas Instruments TI-84 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
There isn't one. To change the angular mode, press MODE, down-arrow to the third line, use left/right-arrow to select the desired mode, press ENTER, then press 2ND [QUIT].
Posted on Jan 14, 2013
Please help me with torque settings for chev utility 1.4 2012 thanks
if your engine code(suffix) is z14xep
head bolts-renew bolts 25nm 60 deg 60 deg 60 deg
main bearings-bolt sizeM6-10nm 60 deg 15 deg
M8-25nm 60 deg 15 deg
big ends-bolt size-M6-10nm 60 deg 15 deg
M6.5-13 nm 60 deg 15 deg
Mar 13, 2016 | Chevrolet Cars & Trucks
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Why won't my sharp EL 531W give me the correct answer for SIN e.g SIN 30 should = 0.5 but my calculator gives me 0.453990
Your calculator is set for GRAD instead of DEG, it means that it takes your input in gradian instead of degrees. You should press the DRG button until it displays DEG instead of GRAD.
Mar 15, 2011 | Office Equipment & Supplies
My HP-12B calculator is in grad mode I need to be in deg, how do I change ?
Is there a button marked DEG->? That is the standard calculator button used to change mode. It could possibly be the shift function of another button.
Mar 05, 2011 | HP Office Equipment & Supplies
What control turn on heat
OK, just set the temperature to 'Auto/Econ' on the buttons on the heater control and adjust the 'temperature' up or down with the hottter/colder buttons until it has a comfortable temperature like 68 deg. F or 72 deg. F. The system should work automatically after that.
Oct 28, 2010 | 1995 Cadillac DeVille
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
Put new piston rings in but dont know the timming marks for it does anyone know
Here is the manual which should give you all you need regarding your bike so rate me if it helps you thanks....
http://www.husqvarnaracingclub.cz/images/home/ohqv/manualy/2003/Workshop/2003%20TE610E-SM610S.pdf
TDC spark 0 deg
exhaust opens: 91deg [89 deg before BDC]
BDC 180 deg [1/2 turn]
intake opens: 310 deg [50 deg before TDC]
TDC lost spark: 360 deg [1 turn]
exhaust closes: 400 deg [40 deg after TDC]
BDC 540 deg [1 1/2 turns]
intake closes: 617 deg [77 deg before TDC]
TDC spark 720 deg = 0 deg [2 turns]
here are some important couple of links...
http://www.advrider.com/forums/showthread.php?t=141762&highlight=Husky+Husqvarna
more on proper nut and bolt securing.....
http://www.advrider.com/forums/showthread.php?t=156429&page=244
Apr 02, 2009 | 2000 Husqvarna TE 610
Help!!
You need to be in the degree mode. To do this push the mode button on the calculator (mine is located near the directional keys). Go down three rows to where it displays RAD DEG. Move your cursor (which is blinking) to DEG and press enter. This will highlight the DEG mode press your 2nd then CLEAR button to Quit back to the main screen.
Oct 10, 2007 | Texas Instruments TI-81 Calculator
Texas Instruments TI-84 Plus Calculator Logo
18 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
