Question about Kenmore 24032\24036 Top Load Washer
Washer won't drain
Before the water would not spin out after wash cycle
by playing with the timer it would drain.
Now it will not agitate , drain or do anything except fill water
Kenmore model 11022722100 70 series
  • 5,911 Answers
The symptoms you describe are typical of a lid switch failure. When a lid switch fails, the washer will fill, but stop at the spin cycle and will not drain. Sometimes it will fill, then stop. The switch is located under the washer top cabinet on the right hand side and is activated by a small plastic piece on the lid (called a "lid strike") through an opening along the right hand side of the casing next to the wash tub opening. First, make sure the lid strike is still intact on the lid. Next, open and close the lid and listen for a "clicking" sound. This is an indication that the lid strike is at least making contact with the switch. Then, check the two screws along the right side of the wash tub opening that hold the lid switch in place. Sometimes the screws come loose or fall out causing the switch to fail to contact the lid strike. In many cases, all that is required is to tighten these screws to realign the switch with the lid strike. If all these preliminary checks fail, the lid switch should eb replaced. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require parts, go to searspartsdirect.com and type in the model number you provided. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike is listed as item number 20.
Some other sites to view are repairclinic.com and appliancepartspros.com. Sometimes these sites offer better pricing on parts.
If you have questions, or if the diagnosis is incorrect, please post back and let me know. I hope this helps you.
NOTE: If the wash tub is full, you DO NOT have to empty to complete this repair. Once a defective switch is replaced, the washer will spin out and drain on its own.
Posted on Jan 23, 2009
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
The washing machinge is not completing the complete cycle
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
As washer was on final spin cycle it sounded like a belt came....
Apr 01, 2009 | Kenmore Washing Machines
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Washer won't advance from cycle to cycle
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
Nov 16, 2008 | Danby DDW1805W Designer Series...
Kenmore 24032\24036 Top Load Washer Logo
240 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
