Question about Jacuzzi Home
I have a jacuzzi aero it will not heat and relay #3 chatters
Model c460000
  • duder32
    duder32 Jan 14, 2013
    i have replaced the relay but now it dose not engage and heat
  • Jacuzzi Master
  • 717 Answers
This chattering means you have a bad relay on your circuit board. It will need to be replaced or you will need to replace the complete circuit board. Since you have tried to replace the relay i would suggest a new circuit board.
RodUS Parts Center888-521-6183
Posted on Feb 07, 2013
DFG-100-3-S temperature control relay chatters and oven temp is all over the place. Is this the temp probe or has the control module gone bad?
I would replace the electrolytic capacitors. Like for like of course. If the smoothing capacitor has dried out, it will not smooth properly and may make the relay chatter.
Feb 06, 2017 | Ovens
Low voltage chatter to the right of the cad cell relay
Cad Cell Relay Control Guide: heating system reset switch ...
inspectapedia.com/heat/Cad_Cell_Relay_Reset_Button.php
LOW VOLTAGE WIRING REPAIR UPGRADE ... LARGER VIEW of an oil burner Cad Cell Relay by Honeywell ... The gray box in the right in this illustration. ... motors including those operating air conditioning fans, heating system oil burners, ...
Oil furnace cad cell and relay - YouTube
? 11:31
https://www.youtube.com/watch?v=SHTwhOtvQWE
Mar 30, 2012 - Uploaded by grayfurnaceman
Explanation of the operation and troubleshoot of the cad cell relayand the cad cell used ... Yeah there's oil and I have tried but I'm not sure if I reset right .... i think it's supposed to be 160 on thelow limit 180 on the high limit....Missing: voltage ‎chatter
Dec 16, 2015 | Heating & Cooling
2005 Honda VT 750 Shadow Aero making a chattering sound
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Rear Chains---RATTLE
5. Cam Chains---CLICKIT
6. Clutches---CHATTER
7. Cylinders---PING
8. Fairing Panels---WHISTLE
9. Fronk Forks---Plunk
10. Gears---WHINE
11. Head Gasket---HISS
12. Hydraulic Lifters---TAP
13. Pistons---SLAP
14. Radiators---GURGLE
15. Rear Chains---RATTLE
16. Rear Shocks---SQUEAK
17. Relays---CLICK&BUZZ
18. Shaft Drives---WHIRR
19. Shifting Trans---CLUNK
20. Solid Lifters---TICK
21. Starters---CLICK
22. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2005 VT750C Aero Engine Noise 2005 VT750C Aero Engine Noise
Clutch Noise SS750 Shadowriders
Honda 1998 VT750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Jul 11, 2014 | 2005 Honda VT 750 Shadow Aero
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
I have a Jacuzzi Aero Select Tub, everytime i
Run an extension cord from another gfci and see if it works. If so, you could have a faulty gfci or issues internally to the motor. Also, if the "home run" for the tub is wired into a sub-panel and the grounds and neutrals are not isolated it could cause problems with a gfci as well.
Hope this helps!
Mike
Feb 02, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
I hae a electric heat pump and gas furnace, when utilizing the heat pump i get chattering from a relay, i have replaced this relay with a new one but continue to get chatter any ideas
chatter on a relay can mean a few things but since you have just tried to replace it, i wouls check the voltage at the relay,,,,
chatter is caused by i mproper voltage at the relay, coil,
Nov 03, 2009 | Heating & Cooling
Jacuzzi hot tub, aero select. pops circuit breaker as soon as switch is thrown. I disconected both motors and panel. still blows. Unit is about 8 Years old. Is there anywhere I can get a schmatic or any...
Your Jacuzzi should be connected to a large GFI breaker. If it pops as soon as you turn something on, there is an imbalance between the legs supplying the power to your device. When my (small "J") jacuzzi (at about age 15) did this, I discovered a small leak that had dripped onto the circuit board and had left a deposit causing a "short". I was able to clean the deposit off of the board physically, I fixed the leak and return my tub to service.
The GFI is very sensitive and for good reason. It protects you from dangerous electric voltages, even though the danger is low.
Oct 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
HUMMING/CHATTERING NOISE ON SANYO TV
Confirmation: Lee2fixit's solution also worked on a Sanyo 19" TV Model DS19580with 'buzzing relay'. Chassis carriessimilar relay (Type DG1U 12VDC II TV-5 8A 250V~ also by DEC) at location RL601and a 25VDC 470uF electrolytic cap at C622. After confirming the relay was sound and finding no obviously faultedcomponents tied to it, replaced the cap. Bingo, normal operation and a quiet relay. Will post a follow-up ONLY if the fix failsbefore the rest of the TV .. it's almost10 years old after all. Thank youLee2fixit and FixIt.com.
Jul 05, 2008 | Televison & Video
Home Logo
57 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
