Not connecting to the internet
Im trying to connect to the internet and it keeps coming up authentication problem any idea
  • 27,725 Answers
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Posted on Jan 14, 2013
jacobvizon
  • 31 Answers
SOURCE: Wont connect to internet
your computer LAN card maybe disable... or not installed...or it needs configuration
Posted on Aug 28, 2008
kchilder
  • 72 Answers
SOURCE: problem with internet connection
Check both your router and your PC configurations. Follow the manufacturer's directions for configuring your router and PC for WiFi access.
Posted on Nov 30, 2009
  • 36 Answers
SOURCE: i cant get connected to the internet everytime i
go to your internet exploror, click "file" on top left of page....check to see if "work offline" is checked..if it is, uncheck it and try again.
Posted on Dec 29, 2009
  • 84 Answers
SOURCE: im having problems with it staying connected for
Unplug your router/and or modem for 15 secs and try it then. Sometimes the router has to reconfigure itself in order for it to stay stable. also be sure not to have any cell phones close by, due to a lot of them operating on the same frequency.
Posted on Mar 31, 2010
g33k4u
  • 485 Answers
SOURCE: Hi, my wireless internet connection
There could be a number of causes for this issue. I will give you some tips to see if you can't resolve the issue.
Make sure your computer and software is up to date. Update windows and update any device drivers for your computer. Do a google search by the brand name of your laptop, go to the website and look up Drivers/Software specifically for your wireless card/motherboard.
The problem could be with your Internet Service provider if you are using your home network. The signal could be degraded and they will have to come out and fix that by replacing splitters and lines at your residence.
You could have an issue with your router. If your router is dropping connections there is not much you can do about this other than replace it. You can try to reset the router(you will lose settings and will have to reconfigure). In order to reset, you can press the small reset button on the back of the router and hold it for 10-15 seconds. You can also rule out the router by bypassing it, hooking your laptop up straight to the modem. If the problem goes away then you know the router is most likely the culprit.
Regards,
G33k
Posted on May 18, 2011
I keep getting authentication problem when trying to connect my smart TV to the internet. I am sure my password is correct and am aware of case sensitivity when entering password. What more can I do?
Try recovering as a factory reset since there may be some problem in your TV's connection. Once you do your factory reset all your settings will be set to default. For factory reset see your TV's Manual.
Dec 28, 2014 | Televison & Video
None of my wifi devices connect to my Huawei E5220 mobile wifi. How do fix this problem? It keeps giving authentication problem
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Aug 11, 2014 | Huawei Computers & Internet
Cannot connect my arnova 7d g3 to the internet keeps saying authentication problem. can anyone help
You don't know the password to your wi-fi protected setup. They changed the password when they changed your equipment. Ensure you have the correct password and that you are not too far from the access point.
Jan 20, 2013 | Tablets & eReaders
Cannot get the internet to work
That means you probably don't have the password or the Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 08, 2012 | Computers & Internet
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Unable to connect to internet through Wi Fi on Nokia E65
You need to "authenticate" the wireless meaning you need the password to the web signal. Your phone may have an internal software issue in which it prevents you from connecting to the internet. Contact your phone company to trouble shoot it or get a replacement phone.
Mar 18, 2009 | Nokia e65 Cellular Phone
I keep getting fauly 8001050f coming
8001050F - Hardware failure. Cannot update firmware or connect to internet.
You may need to check your internet connectivity to make sure you are still connected.
Regards
John
Dec 01, 2008 | Sony Playstation 3 (PS3) Console
User access
what version of vista are you using, this is a very important piece of information, vista home flavors are not very network friendly,I recommend that you keep using XP until a few service packs are out for vista. If your using ultimate then something else would be wrong, possibly a setting on the vista box, Im not real sure how vista's authentication works but if they changed it enough then it might require a compatiblity mode or something in order to authenticate with 2000/xp, but then again i could be wrong and vista might authenticate exactly the same way as 2000/xp, try setting an xp box up as a server and see if the vista box can authenticate with it, if so then maybe 2000 is the problem, sorry i couldnt give an actual solution but im still new to vista myself and dont have any pc's that will run it, my good computers are all macs.
Apr 15, 2007 | Sony StorStation FSV-E1 80 GB Network Hard...
Computers & Internet Logo
David Payne
David Payne
