Question about Brother MFC-7340 All-In-One Laser Printer
Printer says Drum Error - Brother MFC-7340 All-In-One Laser Printer
    Sergeant:
  • 166 Answers
Then the drum (which the toner sets in) most likely needs to be replaced, if you have not replaced it recently. They are only good for so many copies and wear out. Should be DR-360.
Posted on Jan 15, 2013
I Have a message Drum Error on a dcp 7040 and I replaced the drum and the printer cartridge but it still says drum error
Hello
for replaceing drum in brother printer you must turn on your printer and open its door ,then you press clear key on its panel and you notice yes or no on indacter panel ,then you choose yes for replaced drum and close printer door.your printer is ready to use.
Dec 11, 2017 | The Office Equipment & Supplies
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
Aug 29, 2014 | Brother HL 1440 Laser Printer
Drum Error
Sir/Madam
Go To Below official Brother Printer Page For Your problem, DRUM ERROR Brother
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Jan 14, 2014 | Brother Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
59.6M PRINTER ERROR
This error indicates a problem with the magenta drum rotation motor. Remove the magenta drum unit and reseat it. Restart the printer. If the error still continues then replace the drum. You can also look in the install slot for the magenta drum to see if there is any visible damage.
May 28, 2011 | HP LaserJet 9500n Printer
Drum error. dont have user guide. how do i troubleshoot? tried replacing drum but still says drum error.
If the drum is used up you open the front door and press menu or options and tell it it's a new drum, otherwise you clean the metal contacts on the sides of the drum and inside the printer, and run the blue tab back and forth about 20 times. If still drum error you may have a bad power supply.
Jan 30, 2010 | Brother MFC 7840W Printer
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Tally t8024 error message "set drum cartridge"
The 'Set Drum" error indicated the printer is not detecting the drum cartridge as being located in the printer.
I would recommend doing the follwoing;
  1. Ensure the drum cartridge locates correctly in the printer. Remove it and re-seat if necessary.
  2. Ensure the top cover (the one that opens upwards to change the drum) shuts correctly, this cover pushes the drum into the printer.
If the above actions do not fix the problem, I am afraid the covers will need to come of the printer. There is a gear mechanism located on the left side of the printer that operates when the top cover closes.
This gear mechanism will need to be aligned with the alignment marks, it sounds like the gears will have slipped and the timing is slightly out.
Mar 09, 2009 | Tally T8024 Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Brother MFC-7340 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
