Question about Canon PIXMA MX310 All-In-One Printer
Clear out document too long error in fax - Canon PIXMA MX310 All-In-One Printer
2 Suggested Answers
SOURCE: canon laser fax 710 error message 100
e100 is a laser failure.... replace the laser assy
Posted on Mar 04, 2011
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
How can I clear the check document error message?
you have to put out the document and cleaning the Printer, if the error continue for more time, you have to cleaning more, open you eyes much more and find where are not clear!
Aug 02, 2013 | Canon LaserCLASS Fax 710 Printer
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
You can solve the Error 358 by the following:-
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Says there is a paper jam but there is not
First, you have to clear the error first before sending the fax.
-open the rear access door at the back and check if there is any debris of paper. If none, close the access door and make sure you hear the snap and properly closed.
-lift the document feeder cover to check for any debris, and then close it properly.
-if error is cleared, try faxing again
Feb 26, 2009 | HP 1040 Plain Paper Inkjet Fax
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Can not fax any document
when machine clear this problem may be solved, First you make setting as i said to machine. Press buttons respectively as i written function 9 * 8 # 7 then start button , it gives DIAG MODE then press satrt, With the help of star button go to memory clear and press start key. machine cleared memory, gives printing of MEMORY CLEARED. this setting will solved your problem.
May 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon PIXMA MX310 All-In-One Printer Logo
26 people viewed this question
old marine
old marine
