Computers & Internet Logo
Brian Burnett Posted on Jan 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i make my p.c. (desktop)stay on longer before resting.
When i`m reading an article it just`s goes to screen saver to quick is there an adjustment to set it to go off after a longer period.
Shahzad Waseem Akbar
Level 3:
  • Master 746 Answers
  • Posted on Jan 14, 2013
Master
Level 3:
Answers
746
Questions
0
Helped
272383
Points
2750
Hi, its very easy, you need to just change PCs power setting and set on never instead of longer time. Your problem will be resolve.
Enjoy.
  • Brian Burnett
    Brian Burnett Jan 15, 2013
    A big thank you to you Shahzad it worked a treat. Yours Brian.
1 Related Answer
andrew808
  • 14 Answers
  • Posted on Oct 10, 2010
SOURCE: I have the screen saver
1 check your power settings on your computer - your computer may go to standby after so many min of inactiveness. 2. check you monitor hardware setting (refer to your monitor manual) it might have built in energy save mode.
How can I make screen stay on longer it goes off very quickly
On the Desktop screen right click. Hit Personalization. Now change the time configuration from there.
1helpful
2answers
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
My omputer goes back to password very quickly
1) If you are using Windows 7, right-click on the desktop and then left-click on PERSONALIZE. Then select SCREEN SAVER in the lower right corner of the screen. Choose the time you want before the screen saver you want becomes active.
2) Open Control Panel, Select System, Power Options, Change Plan Settings. The next screen will give you the options for controlling your screen time-ou. Set it for however long you want it to be. SAVE/APPLY changes.
After login in my pc goes to a blAck screen and no longer to a sCreen saver, IT takeS toO long
SEEMS TO ME (BLIND) THE Pc is going to sleep mode.
and that is slow. coming out it is.
there is no need for screen saver (no PC TOLD) but screen saver is for destops using pre-2001 CRT cathode Ray Tube monitors
so don's screen saver.
or in control panel , power settings turn off sleep
all that is totally under your control unless you have bad drivers
seen in DEVICE manager
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
A blue screen appears in the place of my screensaver.
i) whenever u keep ur system idle for few minutes or longer time ur system goes in screen saver mode, in order to know more about it......
Screen Saver Mode: when u keep ur system idle for few minutes(say more 10 min or any or u might u kept system idle while you some work to doo...) in such a case u will have graphical picture of a blue screen evolved on your screen, you can even changethe picture or screen saver and keep your own.....
right click on desktop(close all the windows) and select the button Screen Saver and configure to apply your own screen saver(try to explore and learn about it....
Thankin you
M. Sridhar
2answers
My problem is when i am watching a programme i downloaded onto the bbc iplayer or sky player 10 minutes into watching the programme my laptop goes away from the programme i am watching to the acer...
All you need to do is disable the screensaver.
Click anywhere on the desktop that in not occupied by an icon. Select properties, go to screen saver, select none, the hit ok. Your screensaver will no longer come on when you're playing your videos.
Thanks and please take a moment to rate as fixya.
2helpful
Error message
N~ 1.SCR looks like a truncaked screen saver name (when a name is longer then 8 characters, it comes up with the ~) the .scr is a screen saver extension.
Just as something to try, disable any and all screen savers you have running and see it the error stops.
Please inform after trying this.
Grand Canyon Tech
Grand Canyon Tech
