Question about Sewing Machines
Which position shouls my needle be in to thread on my necchi model 574 fb
I dont have the manual for it,should the needle go in sideways or front to back ?
  • josie casavan Jan 15, 2013
    what size needle does yours take
  • I use schmetz universal needles in my necchi's and the needles work great. I have a mechanical and a electronic necchi,, I just change the needle according to the fabric I'm sewing.
  • Sewing Machines Master
  • 7,365 Answers
On my 2 necchi's,, I put the needle in with the flat side to the back
of the machine.
here is 2 links for a manual
http://www.sewingpartsonline.com/instruction-manual-necchi-574fb-download.aspx
http://www.sewingpartsonline.com/instruction-manual-necchi-574fb.aspx
Posted on Jan 14, 2013
SOURCE: Necchi 525 FA model
This site (www.sewusa.com) sells manuals for many types of sewing machines. It also has a section (on left side of home page) that provides basic information about treading (bobbins too) and repair.
I also own a 525 FA and just read that someone considers it is a piece of junk. I'm having problems with the tread breaking constantly (with many hours spent on this problem) and I even have a manual! Perhaps it is a piece of junk?
Marla
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: Necchi BU MIRA threading
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_BU_threading_Diagram.htm
this site has a picture
Posted on Jan 27, 2009
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
Zenqi
  • 208 Answers
SOURCE: Necchi 4757 - need to know which way the needle
Insert the needle with the flat side to the back. Thread the machine from the spool, left to the guide on top/rear, over the top towards the front, around the tensioner and up, around the take-up lever from right to left, down throught th semi-hidden guide, through the needle clamp guide and thread the needle through the front to the back.
Posted on Jul 10, 2009
My upper thread is jaming up underneath the fabric under the foot plate. Its a necchi 535 fa/fb
That is generally called bird nesting or thread nesting, or what I refer to as "thread mess." It occurs because of a top tension issue but usually because the thread is not completely seated in the tension disk.
Remove the top thread from your machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension around the midway point and retest your machine.
Adjust the top tension until the top and bobbin threads meet in the middle of the fabric. (Tighter top tension pulls the bobbin thread up. Looser top tension, the bobbin thread pulls the top thread down.)
Other helpful hints:
Avoid old or bargain bin threads.
Install a brand new needle every 8 hours of sewing or whenever the needle hits something hard like the needle plate or presser foot or gets bent or damaged.
Make sure the needle, thread, and fabric are compatible, ie do not use ball point needles on woven fabrics, do not use a needle which eye is too small for the thread, etc.
Jan 21, 2018 | Necchi Sewing Machines
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
Nov 06, 2017 | Sewing Machines
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
Dec 24, 2015 | Necchi Sewing Machines
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Jul 09, 2010 | Necchi Sewing Machines
The top thread keeps braeking. This is a recent problem. I use singer needles. I live in South Africa. I dont get necchi needles.
Usual causes are:
Weak or inconsistent thread..
Threaded wrong.
Needle installed backwards or not seated.
Incorrect tension or contamination in the tension control.
The key to finding the problem is to manually turn the machine through cycles and watch at what point the thread breaks or is strained excessively.
Dec 14, 2009 | Necchi Sewing Machines
I want to learn how to thresd the sewing machine model 535FA? i don't have the manual for it.
First lift up the presser foot
Then turn the handwheel until the take-up lever is at it's highest
Thread:
From the spool
around the thread guide on the top rear
around the thread guide top front
down and around the tension, pulling up to fully engage the check spring in the tensioner
up and through the take-up lever
down through thread guides to the needle
thread the needle from front to back
Oct 01, 2009 | Necchi Sewing Machines
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
75 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
