The most logical option would be...
- Connect your device to iTunes (The same computer it is set to sync with)
- Hold the power and home buttons
- After the device shuts down, release the power button
- Your device should then be in recovery mode, at which point you may release the home button upon seeing a message on iTunes that basically says it has detected an iPod in recovery mode.
SOURCE: 8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
SOURCE: Disabled 8GB iPod touch, can't enter passcode
I KNOW WATCH U FIRST PRESS THE OFF BUTON AND LET IT TURN OFF THEN PRESS THE HOME BUTTON LET IT PRESSED THEN U PRESS THE OFF BUTOON AND TILL THE ITUNE LOGO WITH THE USB U LET GO BUT UR IPOD HAS TO BE CONNECTED TO ITUNES
SOURCE: passcode screen does not come on, says connect to itunes
Restoring it will not fix this problem. What you need to do is force it into recovery mode. Click the link and it will show you how. This happened to me while I was in a foreign country... I can feel your pain. This works!
http://support.apple.com/kb/HT1808
You may then proceed to restore your device.
