Question about Emerson MW8777W Microwave Oven
As plugged in microwave starts up doesn't stop even if you press clear and it also sparks where can i go to exchange it or have it replaced?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Sounds like someone tried heating something up with metal attached or possibly left a utensil, Chinese food with the metal handles or foil in the unit - throw it out and but a new unit - it's not worth it parts plus labor and it will never work right again the power scale will be off
Posted on Jan 14, 2013
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
Emerson microwave 1100 watt microwave keeps running even when timer stops bought about 7 months ago
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Oct 18, 2011 | Emerson MW8168B Microwave Oven
Most of the buttons on my Goldstar MV1604SB stopped working
Does the display on your microwave read "Locked"? If so, then the Child Lock feature has been activated. To toggle the lock off, press and hold the Stop/Clear pad for more than 4 seconds. When this feature is active, most buttons are disabled to prevent accidental microwave use.
If holding the Stop/Clear button doesn't work, then I'd suggest there is a problem with the contacts behind the buttons. Sears Parts Direct has the parts diagrams for this microwave here: http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/Model-MV1604SB/1366/0123245 . (It's better to replace the control panel then to try to fix it.) Use the part numbers from the list to find price and availability at other sites.
The manual for the MV1604SB is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17638/GOLDSTAR-Countertop-Microwave-L0521424?brand_name_search=loosening+tight+screws .
I hope this helps.
Oct 13, 2011 | Microwave Ovens
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
Microwave is locked
If this is a problem of the control panel being locked, the instructions are posted on page 9 of the owner's manual. Press STOP/CLEAR, followed by pressing and holding the ENTER/START button for 3 seconds. The lock should clear.
If you no longer have an owner's manual, here is a link to a FREE copy:
http://www.managemylife.com/mmh/owner_manuals/15069/JENN-AIR-Countertop-Microwave-L0606616?brand_name_search=JMC9158
If I'm wrong in my assessment, or if you need further guidance, please post back and let me know. I hope this helps you.
May 09, 2011 | Jenn-Air JMC9158AA Convection Microwave...
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Emerson MW8777W Microwave Oven Logo
44 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
