Question about Reddy Heater-30-55,000 BTU Variable
Won't fire I have a reddy 50,000 btu heater [older model] that has fuel and spark,but well not fire. Why? I don't know what the photocell does . Can it be that ? How do you check to see if it works.Or does it either work or not work ? Could the fuel spray be to much to fire?
  • 19,396 Answers
Check that fuel pressure is OK, and also check the air intake is free.
This model should have air filter, in that case replace it.
Here you find also the service and repair manual
SERVICE MANUAL
Posted on Jan 24, 2009
    Scholar:
  • 108 Answers
I believe you have a pressure issue. The pressure should be 3 to 6 psi. Try adjusting to see if that is the problem.
Posted on Jan 23, 2009
    Brigadier General:
  • 5,158 Answers
This site has extensive information on the reddy heaters ... check out the how to information column on the left of the page
http://www.reddyparts.com/
Robert
Reddy heater getting fule,air&fire runs 30 sconds cuts off does not light
Things that can cause this symptom
A dirty fuel nozzle
a dirty photo cell / an inproperly positioned photocell or defective photocell
also cracked fuel hoses
a dirty fuel filter.
a clogged air filter.
Here is a service manual that will help you:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
Read pages 7 - 9 first.
Troubleshooting begins on page 10
Also note that spark plug type models are in section B of the manual that starts on page 25
Thanks for choosing FixYa,
Kelly
Jan 18, 2011 | Reddy Heating & Cooling
My kerosene 50,000 btu reddy heater fires up for about five seconds and then shuts off. I put no. 1 kerosene in so it burns cleaner. It's 2/3s full. the drywallers used it last so it's a little dusty. ...
There is a sensor inside that tells the heater that the flame is lit...if it doesn't "see" the flame it will shut down...this may be caused by the filter in the rear being clogged and it is not allowing the pump to produce enough pressure to ensure a good flame or the pump inside may have sucked up some debris and is now not producing the proper pressure required. Another possibility is that there may be enough dust on the sensor itself to cause it to not "see" the flame...if you take the cover off you can find this sensor...it will have 2 wires coming off of it and it looks like a photocell...it should be located just in front of the jet where the fuel comes out...a word of caution...the ignitor(and the spark plug looking thing) have very high voltage on them(around 5000Volts) so I would avoid touching these parts while in operation.
Dec 08, 2010 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
Nov 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater model r100a runs approxamitly 15 to 20 minutes then kicks out.fan seems to run fine and already replaced the spark plug.
generally if a heater with a spark plug will run for 10 minutes or longer then that’s an indication that the electronics are functioning properly, so for now, eliminate "any fuel delivery problems" before trouble shooting the electronics. The spark plug should spark for the duration of the run time. If the flame goes out the heater shuts down (just like its designed to do). Imagine the fumes & danger involved if the heater continued to pump raw fuel into a hot combustion chamber!
Some possibilities:
  1. the plastic end cover is cracked. When the room heats up the crack expands allowing the air pressure to fluctuate.
  2. the air pump pressure is not correct. (instructions at www.reddyparts.com )
  3. the fuel filter is restricted.
  4. the nozzle is restricted or worn.
  5. there is an air leak between the pump & the nozzle.
  6. water in the fuel. When a droplet passes through there is a momentary flameout condition which will cause the photocell to shut the unit down.
  7. The photocell is defective
Some more troubleshooting tips
Mar 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
R155A Reddy Heater Help!
This is going to be a tough one. You have been thorough, done it right, and it damn sure ought to fire off every time!
There is something that is causing you a problem and don't think that because you put in new parts that you didn't get a bad part. It happens. Not often, but it does happen. I have rec'd nozzles from the factory that had the orifice installed sideways, so, I know it happens.
If the ignitor glows- (it only stays on for 5 seconds, then quits)
If the fuel fogs (not sprays)
If the fuel hits the glowing ignitor
Then it should fire off-- every time.
Now, if the photocell doesn't like what it sees, then the photocell will shut the heater down within 5 seconds, but it at least should have ignited. Right? Unless the photocell or the board are bad. Maybe.
Lift the top, and watch. What's happening. Are you having a fuel problem or an electronics problem? For instance- is the ignitor glowing every time at start up or only sometimes.
Let me know what you find.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater has a spark but does not light up
make sure you put the cover back on or you wont get the right air mixture from the fan.
Jan 08, 2009 | Reddy Heater-30-55,000 BTU Variable
Trys to start. Motor turns slowly (revolution in 2-3 seconds).
Either:
  1. the reset (safety control) is bad
  2. the photocell is defective
  3. both of the above
To test the photocell http://reddyparts.com/photocell_test_sp.htm
Nov 29, 2008 | Reddy Heater-30-55,000 BTU Variable
Wont fire
No solution. The electronic control monitors the flame in the heater using a photocell. The ligth intensity and frequency are monitored to insure that the heater getting a good burn and therefore not emitting a high level of toxic gasses.
Causes:
dirty photocell
bad fuel causing bad flame
Nov 17, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
20 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
