Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Instructions for Intermatic timer Model T101PC
How do i set the timer?
jeltey
  • 44 Answers
SOURCE: how to program Intermatic model T101-70
Do you have the screw on trip pieces? They look like little arrows with a thumb screw on them. Some of them should say On, some Off Place the on trips over the time you want the lights to com on vice versa for off. To set the time pull out on the yellow time wheel and rotate until the arrow that is pointing down is over the current time. I hope this helps.
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: intermatic model HB77R timer
See the page link below, and once there, click instruction manual to see the whole thing. http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Posted on Nov 28, 2009
  • 16 Answers
SOURCE: Lost setting instructions for Intermatic timer
I have located a site which has the instructions for your timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb800r.ashx
I located this while searching for an image of your model timer
Posted on Feb 18, 2010
Testimonial: "Great....thanks...."
SOURCE: I do not have operating
Instructions for DT300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Posted on Oct 12, 2010
Testimonial: "Thanks, The user instructions for my Intermatic 7-day Digital Timer ( Model DT300 Series) is just what I needed"
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Lost setting instructions for Intermatic timer model: HB800RCL. Need help..
Jan 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to set times for Model #HB88RC
I have found the instructions for your model
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
I hope that is this will help resolve your issue
Jan 14, 2010 | Intermatic HB88RC - 7-Day Programmable...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
70 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
