Question about Novatel Wireless Inc Novatel MiFi Liberate AT&T
My mifi liberate always shuts down and the batteries need to be taken out and reinstalled
  • paula133
    paula133 Mar 06, 2013
    I have a MiFI Liberate that I purchased a month ago. The first one kept shutting down at indiscriminate times so I returned it and got another. This one is doing the same thing. Design flaw? Wish someone out there could address this problem.
  • John Williams
    John Williams Mar 10, 2016
    Mine has just started doing the same thing after working fine for several years. Very irritating.
How to open battery compartment on internet to go mifi?
A mifi is usually about the size of a credit card. One side will feature an on/off button and a logo. Turn it over. Look for a small arrow and press down in the direction the arrow is facing and the battery cover will slide off.
Jul 23, 2014 | Computers & Internet
Reset novatel mifi 2200
There is a small hole just above the battery cover; this is the reset. Place a pin inside and press down to reset device.
Mar 12, 2014 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Freezing on startup
connect to a pc/laptop. in my computer go to properties of the drive and defrag the drive. see if this works for you. it does some times.
Mar 09, 2014 | Novatel Wireless Inc Novatel MiFi Liberate...
I need the Huawei E5375 mobile MIFI users manual in English
The Huawei E5375 is a customized Chinese version. And it is similar with the Huawei E5372 which is in English version. So, you could find the E5372 user manual, they are the same. Huawei E5372 LTE CAT4 4G Mobile Router
Jan 26, 2014 | 2003 Chevrolet TrailBlazer
I can't get on any other screen other than the home page of my mifi liberate
Typically the carriers require you to sign in on the mifi home page to setup your mifi. Once you have gone through the setup you will then setup a typical wireless connection using the SSID and Password either setup or given to you by AT&T. Does the home page have a sign in or setup area? If so that is where I would start.
Jan 06, 2014 | Novatel Wireless Inc Novatel MiFi Liberate...
After start up a spinning square
follow this chart guide for troubleshooting and fix it. God bless you
see the status light see your owner manual. or download from www.retrevo.com
Nov 05, 2013 | Novatel Wireless Inc Novatel MiFi Liberate...
My mifi only goes to the att page
Mine does the same thing. If you find the solution, please let me know.
Apr 01, 2013 | Novatel Wireless Inc Novatel MiFi Liberate...
Verizon MiFi 2200 blinks red then shuts itself off when I plug it in. I know red blinking means critically low, but it won't charge and I have left it plugged in for hours. I held the reset button down for...
Mine did this, I went to Best Buy where I bought it. They didn't really seem to know, said it could be the power cord to the wall, but they didn't sell them. But they could set me up with an upgrade (and new 2 year contract that I didn't want). Anyway, I went to Radio Shack and showed them my MiFi 2200 and they had the new wall charger power cord there. Works now, problem solved for $25 instead of a new 2 year contract.
Jan 17, 2011 | Novatel MiFi 2200 Mobile WiFi Hotspot...
How do i connect MiFi2200 to a wrt54g?
I think this won't work...the MIFI device works as a wireless router that can supply 5 connections and runs on battery which last for 4 hours for one connection then goes down as more connections are in...the MIFI was designed for mobility as the WRT54G is not...I don't exactly know what your plans are but this won't work well.
The Verizon MiFi is a combination 3G modem and Wi-Fi router that is battery-operated for full mobility. Once the MiFi has been activated (more on that later) the device connects to the Verizon Mobile Broadband network (renamed from BroadbandAccess) simply by pushing the power button. In just a few seconds, the MiFi is connected to the 3G high-speed network and the Wi-Fi router takes over. The MiFi appears as a hotspot to any device with Wi-Fi capability, and making the Wi-Fi connection is as simple as entering the network security code which is printed on the back of the MiFi. That’s it: The notebook or other device is now connected to the Verizon network via Wi-Fi. The network code only has to be entered to make the first connection, after which it’s an automatic process. That’s the beauty of the MiFi method: Push the power button and the laptop/UMPC/phone is connected to 3G.
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
Novatel Wireless Inc Novatel MiFi Liberate AT&T Logo
768 people viewed this question
Top Novatel Wireless Inc Computers & Internet Experts
David Payne
David Payne
Are you a Novatel Wireless Inc Computer and Internet Expert? Answer questions, earn points and help others
