Question about Saeco Vienna Espresso Machine
SAECO VIENNA ESPRESSO/COFFEE MACHINE
I,ve had this espresso mACHINE FOR ABOUT A MONTH ,THIS IS MY SECOND ONE MY FIRST GOT WATER IN THE TOP GRILL WHICH FRIED THE SYSTEM,THIS SYSTEM SEEMS TO WORK GREAT ,BUT ALL OF A SUDDEN AFTER THE MACHINE GRINDS THE COFFEE IT BUZZEZ TWICE THIS NEVER HAPPENED BEFORE NOT EVEN IN MY FIRST MACHINE DOES ANYONE HAVE A CLUE WHY THIS IS HAPPENING? THANX JB
    Problem Solver:
  • 6 Answers
Sounds like it could have pre brewing enabled which wets out the coffee and helps extract the full flavour. It may also need lubricating it is hard to know with a limited description. You can use a pen to bypass the sensor in the door to see what it is doing at the time. This may or should help establish the noise.
Posted on Aug 30, 2007
SOURCE:
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
How do I change the aqua filter in the Saeco Vienna Automatica machine?
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna not brewing
I wish I could post a solution, but this is exactly what happened to my machine after about a month of use. I don't see any clog nor a way to get to the moving parts that could create a clog. Unfortunate design.
Nov 28, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna Espresso Machine Logo
139 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
