After sitting idle for awhile, it goes into "Sleep Mode" (at least that is what I call it). Sometimes I am able to push the display screen to Wake it up, but usually, it refuses to wake up. I then have to unplug then plug it in again. After waiting an eternity for the self-diagnostic to finish, it works fine. Can I set it not to go to sleep?
SOURCE: My HP Officejet 6500 wirless
Solution one: Plug the product directly into a wall outlet to make sure the power source functions correctly.
1. Disconnect the power cord from the back of the product.
2. Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
3. Reconnect the power cord to the back of the product.
4. Try to print again from the computer.
NOTE: If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not allow enough voltage to reach the product.
If the issue persists , continue to the next solution.
Solution two: A semi-full reset returns the following settings to the factory defaults:
· User menu settings · Telephony parameter values · Country and language selection · Fax memory · Fax journal information · Speed dial and broadcast lists · Personal header information · Junk file numbers
1. Press the Power button to turn off the product, and then unplug the power cord from the wall outlet.2. Disconnect the power cord from the back of the product, and then wait 20 seconds. 3. Plug the power cord into the wall outlet. 4. Press and hold # and 6 while reconnecting the power cord to the back of the product. Press the Power button to turn on the product, and then follow the instructions that display on the control panel to select the product settings.
SOURCE: Printer will not wake from sleep mode to print
switch offfff,,, remove the plug ... plug it again ,,, restart pc ,,, switch it on.................hope it works
SOURCE: 4350 nosiy while in sleep mode
If it comes out of "sleep mode" every 10 minutes, and you haven't touched the printer or sent any data to the printer, try unplugging the LAN cable for 15 minutes. If the printer stays in "sleep mode"either the formatter is bad or whatever is on the other end of the LAN cable could be bad. If you can put the printer on another PC to see what happens, that would really help you out.
SOURCE: sleep mode does not wake up
In most cases the formatter board is causing this problem. The only way to solve it is replacing the formatter board
SOURCE: I have an officejet 6500
have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
