Question about Bowflex WR30M EZ Pro Strapless Heart Rate Monitor
My Bowflex WR30M watch band broke and need a new one.
Where do a get a new band for my watch
How to make my Timex indigo WR30M expansion band smaller it diesnt have pins ti remove in order to take out links
there is a method to do this but it takes a watch maker or jeweller to do the job
Take it in and have it adjusted
Sep 22, 2016 | Timex Watches
How to make an expansion watch band smaller for A timex WR30M
I would need to see the watch band, even the same model may use different bands.
Can I swim with the EZ PRO
You can if you want to. However those watches have problems and one thing that people complained about is the sensor button no longer working after swimming
Jan 29, 2014 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Need a manual
You can get the pdf format.
Just make sure you have the adobe reader which is free for download. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Dec 25, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
My Skechers GOwalk Strapless Heart Rate Monitor (Basic; Model Number WR30M; Distributed by Sports Beat, Inc.) will not read the heart rate. I bought this digital watch new, and it worked in reading the...
Well it depends on how much you sweat.
The sensors need to be wet to read correctly.
You can buy something called Heart Rate Gel cost about $5 to $10
Some people just lick the sensors on the watch strap and it works until they can start sweat enough..
Hope this helps.
Nov 03, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Bowflex
Jan 08, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
The band for the watch broke. Do you sell bands for the casio AMW 330?
mcdevito75 here, Hello, Mike D from RITE TIME BASICS, we are listed in the Repair Service Directory right here at fixya. I would need your Casio watch here with me for fitting of the new band, for a few days, I may also have to order a new band for your watch if you wanted a Genuine Casio Band. Bottom of this page, Click on Repair Service Directory, then watches, we are the RITE TIME BASICS email, mcdevito@netzero.com
Aug 19, 2010 | Casio AMW330-7AV Wrist Watch for Men
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
Bowflex WR30M EZ Pro Strapless Heart Rate Monitor Logo
387 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
