Question about Dell Inspiron 2650 Notebook
What controls memory capacity?
All the follwing questions are base don memory CAPACITY that can be installed not how much is installed when it is produced and sold.
What controls the memory capacity for a given computer, the chip set used, the motherboard used or something else?
For instance, if a given chipset, say an Intel xxx, is isued on different motherboards will all of the motherboards using that chip set have the same memory capacity ( I relaize that the motherboard may have less slots than the chip set will support, but assuming both boards have same slots on it)?
Next step, assuming that you have the same motherboard, will all computers using that same board have the same memory capacty or can the computer manufacturer control the memory capacity during the assembly process or during programing?
Next step, assuming that all the computers have the same motherboard and are in the same brand of computer, will they all have the same memory capacity or will that vary with model?
Thank you for your patience with my ignorance.
Don Jones
  • 3 more comments
  • donejjones Jan 23, 2009
    rtrahan,
    Let me put it anothe way, IF DELL uses the same motherboard in 2 different models of a laptop, will both of the them support the same amount of memory?
    The reason I am asking is the DELL tech representative told me that even though the upgrade manuals list 512 as sthe maximum memory that my 2650 will support, it uses te same motherboard as a later model that they used 2 gig in. He took a 2650 test machine from their lab and insterted a 1 gig module in the user accessable slot and checked it out. He said it worked fine. He had no reason to lie to me and in fact took my phone number and called me back after he tested it persomnally to verify that it worked.
    Last night I purchased and installed a PNY 1 gig PC 2700 modul that is labeled as backwards comaptible clear back to PC 1600 in my user acessable slot and it would boot up. It acted like there was no module in it. The package the module came in was labeled as "Compatable with / Avec / Con".
    I have used a DELL PC2100 256 meg module from my son's Insipron 8500 in my 2650 to see if it would work with the faster memory and it worked fine.
    What I am trying to determine is whether the module is incompatible with the DELL system or is there something else wrong?
    Thank you for your help.
  • donejjones Jan 24, 2009
    OK, I think I understand. If the "hidden" moduel is a PC 1600 and the user accessible one is a PC2700 they won't work, but 2 PC2700 modules woud, right?
    The next question is, will the 2650 run with only one module instead of 2 installed at least long enough to confirm that the 1 gig modules will work before I purchase another one?
    Thanks again for the help.
    I removed both 256 modules, installed the single 1 gig module of PC 2700 and reassembled the machine. When I tried to power up, the power light would come on and stay on, but that was all that happened, just like there either was no memory or bad memory in it.
    The 1 gig module was a PNY 1 gig PC 2700 module. The package the module came in was labeled as "Compatable with / Avec / Con".
    I have always been told and have found that if the module was too bg, the machine woouldonly use as much of the memory as it could handle just like installing a over capacity HD works, it just wastes HD capacity or faster memory will run slower.
    Is my problem that the new module is (A) too big or (B) incompatible with the DELL System?
    Thank you for your knowledge and patience.
    Don Jones
    Here is the best I can do on the cut & paste. If you can't read it, let me know what information you need and I'll try to copy it.
    Well, so much for that. I can't make it paste into the comment box so I'll summarize the informaiton down ot the directory level and if you need the rest I'll send it later.
    Operating system XP PRO version 5.1.2600 SP 3
    Manufacturer DELL Computer Corp.
    Model Inspiron 2650
    System type X86 based PC
    Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel 2392 MHZ
    BIOS version/date Pheonix Tech A10, 6/10/2003
    SMBIOS version 2.3
    I have been told that DELL laptops are very finicky about what memory will work. Do you have any suggestions on retail brands to buy?
    The module label says it is 1GB.DDR.SODIMM.N ram.
    Am I correct in assuming that PNY is not high grade memory?
    I have been told that cheap memory doesn't work well in DELLS, is that your experience?
    I think you are suggesting rying a better grade of memory. Is that correct?
    Thak you again.
    Don Jones
  • 741 Answers
The maximum amount any computer will work on is 4 gigabytes. You may see some specialty models with 6GB but that is a waste of money because programmers write programs for a maximum of 4GB as that is the industry standard. The maximum memory capacity depends on the motherboard setup. For instance, any desktop can take up to 4 GB but some smaller laptops cannot. It depends on the company selling the product as they decide which motherboard to install. Netbooks, 7" to 10" screen can only hold 2 GB, while all 15" and above laptops can hold 4 GB. So basically 4GB max or less. Obviously 4GB will run faster than anything less. Memory is fairly cheap so always go with the 4GB. Second part of your question,manufacturers decide which motherboards go into which computers and the larger dealers like Dell, HP, Compaq, etc will always offer 4 GB. Inexpensive computers like Emachine cut cost by not spending the money for the best motherboards so they may only hold 2GB. Hope this answers your questions.
Don't forget to rate this solution before logging out.
Posted on Jan 23, 2009
  • 2 more comments
  • Randall  Trahan
    Randall Trahan Jan 23, 2009
    Yes, the system board model has the same specifications across the board no matter what they name the PC. Another words a PC1600 is a PC1600 no matter what you call the computer. Here is why. The data speed on a motherboard is determined by its clock speed. It has a clock that pushes data for a "1600" at 100MHz per second. The "1600" is the throughput. The equation is: 100MHz using Double Data Rate (DDR) RAM means its pushing at the up cycle and down cycle so that makes it 200MHz. It pushes data in 8-byte chunks so 8 times 200MHz has a 1600 throughput. Hence, the PC1600. So any motherboard rated at PC1600 will all be the same. If you put it in your system just make sure it is the only RAM stick installed. If you mix speeds then you get unstable results. But yes it should work, faster RAM does not cause any problems but your system will still only run at 1600. Hope this helps, if you have any more questions let me know.
  • Randall  Trahan
    Randall Trahan Jan 24, 2009
    Yes, the 1GB stick will work.It when you mix capacities that you may have problems for instance installing a 1GB stick along with a 512MB stick. If you can boot up and get on the Internet follow this website, it has a free download for a program called "MemTest". When you download it and run it, it will examine your RAM to ensure it is working properly. It is an easy click and read program. I and many others use it to make sure the RAM is functioning properly. http://hcidesign.com/memtest/
    Once you download it you will need to unzip it. Download a program called WinZip to do it. If you have any questions let me know.
  • Randall  Trahan
    As of this moment it is incompatible because it will not boot up to the Windows logo. Otherwise, it would allow you to log in, it just would only use the 512 amout of RAM vs 1GB.
    Let me do some more research on the Dell 2650. Click on start>programs>accessories>system tools>system information. On the first page is will have OS version, Manufacturer, BIOs version, etc. Cut and paste that page onto this website and send to me so I can see what I am dealing with.
  • Randall  Trahan
    Well all is well with your system information. According to the textbooks and my own experience there is no reason your computer should not start up with the 1GB of RAM. It could be the quality. I buy all of my RAM from www.crucial.com or www.newegg.com. Both places are great. The only thing you need to make sure of is that you match DDR with DDR and DDR2 with DDR2. It should say it on the stick of RAM. It stands for Double Data Rate and as I explained earlier it pumps data on the up and down cycle of your system clock. DDR2 pumps it twice on the up cycle and twice on the down cycle so RAM is moving twice as fast as DDR. Also SODIMM is for laptops and DIMM is for desktops. As long as those match with what you have you will be ok. The computer companies have made buying RAM difficult but its worth it as it is so much faster.
My motherbaord has only two slots for DDR2 RAM.Both slots are filled With 1GB DDR2 Ram Each.I want to increase RAM memory . Without Removing previous Ram from their slots.How to Solve the above problem.
Buy a new computer with more than 2 Gigs of RAM installed. Problem solved.
Otherwise I guess I simply don't understand why you would not want to remove the 2 smaller RAM modules and just replace them with larger capacity ones.
If you do decide to upgrade the memory, then one good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
Oct 12, 2011 | Computers & Internet
I have a Uniden TRU8885 - 3 Base, when I plug into power suply, it turn on, but after the base turn on and display the message welcome, the base turn off
buy higher capacity power adapter 9volts 1000mA capacity and use ensuring correct polarity, it will work. i had the problem and adopted this and this works ok. also ensure your handset battery is new and charged after installing the higher capacity power adapter. good luck. venkataramani
Aug 27, 2011 | Uniden TRU8885-2 Cordless Phone
My HDD Dell 300GB 15K 3.5" SAS, i used with Windows Server 2008 Enterprise. The problem after installing the hdd total capacity its 279 How can manage this? Thank you
Hard drive manufacturers market drives in terms of decimal (base 10) capacity. In decimal notation, one megabyte (MB) is equal to 1,000,000 bytes, one gigabyte (GB) is equal to 1,000,000,000 bytes, and one terabyte (TB) is equal to 1,000,000,000,000 bytes.
Programs such as FDISK, system BIOS, Windows, and MacOS use the binary (base 2) numbering system. In the binary numbering system, one megabyte is equal to 1,048,576 bytes, one gigabyte is equal to 1,073,741,824 bytes, and one terabyte is equal to 1,099,511,627,776 bytes.
Simply put, decimal and binary translates to the same amount of storage capacity. Let's say you wanted to measure the distance from point A to point B. The distance from A to B is 1 kilometer or .621 miles. It is the same distance, but it is reported differently due to the measurement.
Capacity Calculation Formula
Decimal capacity / 1,048,576 = Binary MB capacity
Decimal capacity / 1,073,741,824 = Binary GB capacity
Decimal capacity / 1,099,511,627,776 = Decimal TB capacity
Example:
A 500 GB hard drive is approximately 500,000,000,000 bytes (500 x 1,000,000,000).
500,000,000,000 / 1,048,576 = 476,837 megabytes (MB) = 465 gigabytes (GB)
Mar 07, 2011 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
    The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
    As for hard drives, the board has the capacity of:
    PATA (Parallel) - 2 x ATA100 4 Dev. Max
    SATA 1.5 Gb/s - 2
    I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
    As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
    Nov 19, 2010 | ASUS P5VDC-X Motherboard
    Micro cd 2 gb memory card is not open pc windo
    From Microsoft support:
    Some Secure Digital (SD) cards do not work correctly on Windows XP-based computers. Additionally, you may notice a yellow exclamation mark (!) next to the SD card in Device Manager.
    This problem may occur even though you have applied other hotfixes that are required for high-capacity SD card support. For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 923293 The 923293 hotfix adds support for SD High Capacity memory cards in Windows XP 934428 Hotfix for Windows XP that adds support for SDHC cards that have a capacity of more than 4 GB
    Aug 15, 2010 | Kingston 2GB Secure Digital Memory Card
    2Gb Micro sd card not recognized by xp pc.
    Apr 15, 2010 | Kingston 2GB Secure Digital Memory Card
    What is the maximum memory capacity of acer aspire 5600 model
    According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
    Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
    External Hard drive 750 gb does not meet the storage capacity as describe
    Hi scotti0619,
    The answer to this question is spelled out by the manufacturer, Western Digital, at http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=615&p_created=1034613413&p_sid=coT55l9j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEsMzEmcF9wcm9kcz0yMjgsMjA5LDIyMiZwX2NhdHM9JnBfcHY9My4yMjImcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1mb3JtYXR0ZWQgY2FwYWNpdHk*&p_li=&p_topview=1.
    The capacity you are seeing is alcuatlly measured in a binary (base 2) system rather than the simplistic base 10 system of 1 GB = 1,000,000,000 bytes. In binary measurement, 1 GB = 1,073,724,841 bytes. Thus, 750 GB in base 10 = 698.47 GB in base 2. You are likely getting the full capacity from your drive, but it is simply being looked at on a different scale.
    Thank you,
    Jason,
    Go Ahead. Use Us.
    Jul 21, 2008 | Western Digital My Book Essential Edition...
    Dell Inspiron 2650 Notebook Logo
    347 people viewed this question
    Alun Cox
