Question about Kenmore Compact Refrigerator 126-Can Beverage Center 9910
How to fix kenmore 99100 compressor
Unit is making a loud vibrating knock sort of sound as well as thermostat temp not being cool as it once was. i would like to repair my self i believe it is a compressor please help by telling what i should do or how to change it. thanks in advance :)
22yooper
  • 828 Answers
SOURCE: kenmore 25351694100 compressor not operating
There may be power to the compressor. You can check it with a volt meter by checking the two electrical leads at their connections.
across the line you should read 120 Volts. This indicated power is there to the compressor and your overload protector may be open. The overload "protector" and "relay" can be ordered from Sears by your model and serial number along with the names of the parts for the compressor.
Posted on Jul 07, 2008
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
mastatech
  • 478 Answers
SOURCE: Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Posted on Mar 28, 2009
SOURCE: frige not cold
hi, i own a kenmore side by side and the fridge part is not cooling . what can i do?
Posted on May 28, 2009
My KSRP25FNSS makes a strange knocking noise at each compressor shut down and sometimes during running. The noise is always a series of 5 knocks, very loud, in quick succession that telegraphs though
By you discription above it sounds like one of the three spring the supports the compressor pump has failed or broke. Now the only fix is to have the compressor replaced, but if the unit is still cooling, currently its a noise problem only. I hope this helps you. If this is still under a warranty, ask for it to be checked as if in warranty it needs to be replaced. Good Luck
Jan 04, 2015 | KitchenAid KSRP25FNSS Side by Side...
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
After compressor on,Sears/Kenmore ac makes a loud vibration noise
sounds like head pressure problem it is most likely clogged on condenser try washing out really good then try again
Sep 10, 2009 | Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
I have a loud knocking noise coming from my window unit a/c. What could be the problem?
This could be the evaporator/condenser fan blades striking the housing or it could be the compressor.
Turn the unit to "fan only" and see if it makes the sound you describe. If so, there is an issue with the fan. You may need to remove the outer cover and see why the fan is making noise. Look for debris, or insect nests that may have taken up residence. If no obstructions, look for bent, cracked or broken blades and possibly loose blades. Make sure the A/C unit is unplugged before working on it.
If no noise in the fan mode, turn the selector switch to cool, being sure that the thermostat is set low enough for the unit to try and cool. If the sound is emanating from the compressor, there isn't much that can be done in terms of repair and it may be time to replace the A/C unit. Compressors aren't usually worth the cost of repairs.
Apr 30, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Compressor makes a loud grumble an vibrates when it shuts off
There are springs inside the compressor that suspend the motor. When one or more of those springs break then the motor will knock against the casing when it shuts down and loses centrifuge motion. The compressor will continue to run up until the point the it beats itself to death, which could be next week of next year. There's no way to tell. The only solution is to replace the compressor.
Oct 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Kenmore Compact Refrigerator 126-Can Beverage Center 9910 Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
